Family man's ae86
01-23-2020, 11:29 PM
Post: #51
Family man's ae86
The press is some nice home fabrication and the trumpets look good!
01-27-2020, 09:42 AM
(This post was last modified: 01-27-2020 09:44 AM by fantapants.)
Post: #52
Family man's ae86
Thanks man.
Been a bit slow with cash, but while I wait for bits to come in, I have managed to button up the fuel system. Well the bum anyway. . It's a ke70 tank, s13 cradle welded in with a Holley hydramat and walbro 255 pump. Again, it's a bits a. The main feed to the front is 3/8 Lol from when I was gunna run the uz. I'm using the old feed as the return. The cradle has 5/16 inlet and outlet, so there is some home made adaptors from a big old bolt. Not perfect but will get it running lol. Tank was given a birthday also, with internal seal paint thing done and a new coat of racing black outside. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Sent from my SM-G960F using Tapatalk And more ![]() ![]() ![]() ![]() Sent from my SM-G960F using Tapatalk clutch kick, switch, tree .... oowwww |
01-27-2020, 02:40 PM
Post: #53
Family man's ae86
To be on the save side, You may want to add a short grounding wire from the chassis to the gas tank. Dave W
01-30-2020, 10:52 AM
(This post was last modified: 01-30-2020 10:56 AM by fantapants.)
Post: #54
Family man's ae86
Yeah that's the plan. There is a small earth for the cradle itself (it's isolated by the rubber oring) and I'll do one specifically for the tank also.
So I scrounge some cash up and got some pretty new 8.8 bolts for the rear end. Hurt a lot having to actually spend money lol. But managed a dry fit of the suspension and wheels. Good news, it all got a about as perfectly as I could have hoped for. Bad news, I need to remake the two top arms for chassis clearance lol. But all progress ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Sent from my SM-G960F using Tapatalk Forgot these bits. I had fucked up a bit with the tank and hadn't allocated for a breather. So did some hacking and welding and set up a breather from the tank cradle cap to the car hard lines ![]() Sent from my SM-G960F using Tapatalk clutch kick, switch, tree .... oowwww |
02-01-2020, 10:51 AM
Post: #55
Family man's ae86
Blech.
One of those days. Remade the front arms to clear the chassis. But cos I'm a dickhead, they didn't clear the cradle mount. Take 2 was more successful. Not exactly pretty, and I'll do it properly with some rod ends and chromemolly down the track, but this will get it going. ![]() ![]() ![]() ![]() Sent from my SM-G960F using Tapatalk clutch kick, switch, tree .... oowwww |
02-13-2020, 10:39 AM
(This post was last modified: 02-13-2020 10:43 AM by fantapants.)
Post: #56
Family man's ae86
Made a few small steps in progress.
Ran out of subtle black paint. See if you can pick where... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Sent from my SM-G960F using Tapatalk Today saw the wheels go on both sides of the car... the driver side has a bit more metal missing for suspension travel. I can tuck plenty of time before bottoming out. Will trim to match the other side shortly. Also sorted the bulk of the handbrake stiff. I'm not convinced it's a perfect solution, but will see how it goes. ![]() ![]() ![]() ![]() ![]() ![]() ![]() Sent from my SM-G960F using Tapatalk clutch kick, switch, tree .... oowwww |
02-13-2020, 12:32 PM
Post: #57
Family man's ae86
Good progress, not too sure about the handbrake solution though..
02-16-2020, 01:01 PM
Post: #58
Family man's ae86
Yeah look the jury is out for the moment lol
Once I can get some pads in there I can give it a test pull and see. My brain says the stops are simply holding th3 force of the outer sliding against the internal cable, a d it's the cable that sees load. But I'm open to the idea that I fucked up lol once w ever some pads in I'll know soon enough. Sent from my SM-G960F using Tapatalk clutch kick, switch, tree .... oowwww |
05-13-2020, 10:33 AM
Post: #59
Family man's ae86
Sir, I commend you for being an engineer. I have been going through this thread and it looks really good. Amazing work, looking forward to the result and really curious how it will drive
![]() Cars: "99 Lexus IS200 "86 AE86 Kouki Panda Levin GT-Apex (restore project) "84 AE86 Zenki Blue Levin (project racer) Motorcycles: "02 Yamaha R1 "02 Honda Hornet S "08 BMW R1200GS |
07-13-2020, 10:48 AM
(This post was last modified: 07-13-2020 11:14 AM by fantapants.)
Post: #60
Family man's ae86
Sorry lads i lost tapatalk for a while.
Lots has been happening and progress has been made. I'll do a quick shoot through of where im at, but if you want any details hit me up and I'll try and answer anything. ![]() ![]() Sent from my SM-G960F using Tapatalk So been a while. I lost tapatalk for a bit after PayPal fucked my account. Anyways, once the worst of winter seemed over, I've managed a solid few weeks of progress. Old girl is dangerously close to some sort of achievement. I needed to relocate the car a bit for access to the front. Hence the gratuitous shot on 4 wheels. So i set about figuring out the engine position ans stuff. Gave up trying to be tricky abd used 20mm crossmember spacers for clearance. (Its ok, its treated pine..... :/ only temp to work out sizing. ) The eyeball work i did early on started to come back to bite me, with the shift position being too far forward. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Sent from my SM-G960F using Tapatalk Sent from my SM-G960F using Tapatalk So set about making the engine and box a permamnat resident of the car. Started with the box end and worked forward. Clearance looks a bit tight iver the steering shaft, but its near 10mm at the closest Random colors simply cos i ran out of black lol made me a yondu bracket. ![]() ![]() ![]() ![]() ![]() ![]() ![]() Sent from my SM-G960F using Tapatalk Sent from my SM-G960F using Tapatalk As you can see in the last pics, the eyeball drug induced guestimations I did early on just keep on giving. The extractors were so badly on the piss lol. But I stoiclly ignored that and went on with the engine mounts. And thats the engine in its final spot. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Sent from my SM-G960F using Tapatalk Sent from my SM-G960F using Tapatalk Sump clearance is okkkkkkk..... im gonna use a slimmer bolt and weld a small v shield informed of the bolt. It sits about 4 or5 mm below the cross member line. Also took the chance to finish off the front half of the exhaust. Made a poor mans slip joint at the front, And even out the rear bumper on to see how bad that build had gone lol. Actually was pretty good lol ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Sent from my SM-G960F using Tapatalk Sent from my SM-G960F using Tapatalk Had a small victory with the stearing uni joint. Had been stressing over how to make up the difference with the dropped crossmember . In the end, I randomly tried a second uni joint from the other crossmember, turned out it was perfectly 20mm longer . Sent from my SM-G960F using Tapatalk Sent from my SM-G960F using Tapatalk So I had to set about moving the shifter back a bit. As it sat, tbe gear stick was hard against the radio in 1st and 3rd lol Also sorted the reattachement of the radiator support panel. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Sent from my SM-G960F using Tapatalk Sent from my SM-G960F using Tapatalk Needed trumpets for the throttles. This posed a problem s I had clearance issues with the brake booster and the bonnet lol. Eventuslly I plan on a booster delete to gain the space needed for a decent plenum, but for now, i present "the winky wonky donkey dicks" ![]() ![]() ![]() ![]() ![]() ![]() ![]() Sent from my SM-G960F using Tapatalk Sent from my SM-G960F using Tapatalk One of my lesser moments was turning the old girl over on the rotiserie before i had the car port up lol. She filled with so much water i had to drill a small hole in the roof as a drain lol.. But that left the roof lining a bit worse for wesr. A few days with the heater going and a can of Mr sheen later, its came up not too shit lol. ![]() ![]() ![]() ![]() Sent from my SM-G960F using Tapatalk Sent from my SM-G960F using Tapatalk One of my lesser moments was turning the old girl over on the rotiserie before i had the car port up lol. She filled with so much water i had to drill a small hole in the roof as a drain lol.. But that left the roof lining a bit worse for wesr. A few days with the heater going and a can of Mr sheen later, its came up not too shit lol. ![]() ![]() ![]() ![]() Sent from my SM-G960F using Tapatalk Sent from my SM-G960F using Tapatalk Final bit of adventure so far is trying to sort out the manifold. I chopped her to bits and set about doing it in the car. Am using more slip joints for ease of making. And thats about it... need to sort a tailshaft out, and a million little bits and pieces, but she is progressing solidly. Hit a wall with the wiring. I'm just not confident enough with an entirely new skill lol. So a mate is gknna come and help me with that bit once the rest is sorted. I also have some rust work that needs doing, but its all easy to do while the csr is driving. At the moment, driving is the main goal. I can sort little bits like the longer lca and rust and proper trumpets and filter etc then. ![]() ![]() ![]() Sent from my SM-G960F using Tapatalk Sent from my SM-G960F using Tapatalk So todays adventure were modest. I had hopes for getting the radiator mounting sorted. I used some commonwhore lower mounts (cheapest things i could find ) and made a bracket that bolts onto the lower sill. Had no idea how i was ganna make it work, but fumbled my way through the top mountz also. Figured i should chuck the bonnet on and see if things fit. Turns out i was a bit preemptive with winky wonly donky dicks, and the straight trumoets fits under the bonnet. So i have ummed and ahhed for ages about wanting to do a booster delete. I couldnt afford the grand chase bays wants for their tidy little setup. But did some thinking and measuring and have bitten the bullet on a plan. If i redrill the pedal 25mm further up, i gain a pedal ratio of 6.1 to 1. That seems the go to for manual brakes. Ive ordered a bm44 2 port master, a chunk of aluminium for the adaptor plate, and am waiting on a gktech abs delete hose kit. This kit should bolt everything up and finalise the brake setup (lines anyways lol) the booster delete means i should be able to remove the last of the winky wonky donkey dicks lol ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Sent from my SM-G960F using Tapatalk Sent from my SM-G960F using Tapatalk clutch kick, switch, tree .... oowwww |
Banpei's new TA60 family cruiser | banpei | 281 | 268,977 |
10-30-2024 11:48 PM Last Post: DarkSupra |
