Finish Exhaust Martelius
07-03-2013, 12:50 PM
Post: #41
i checked brave before,and i didnt spot a middle damper(pot? how is it called in english),thats why i skipped the exhaust system.
also the exhaust db is 95db so probably bit more and then i cant drive on zolder.
07-03-2013, 12:57 PM
Post: #42
OEM exhaust (map version, so without the catalytic converter) = 92dB
I hardly believe that ANY custom exhaust would make you able to stay under 93dB Confused
07-03-2013, 07:55 PM
Post: #43
Ow shit i made an error on the db its 95db in stead of 93db
so if you could chose for 4AGZE ae101 which one would you chose
janspeed bigbore but in mild steel... 58mm bore
Martelius 51 mm
brave but i think it has a cat,im very against cat Big Grin
07-03-2013, 09:28 PM
Post: #44
ditn Wrote:Ow shit i made an error on the db its 95db in stead of 93db
Martelius 51 mm
No cat... mid length resonator, and muffler
[Image: AEU86 AE86 - Finish Exhaust Martelius]
Dan -
07-03-2013, 09:29 PM
Post: #45
Martelius 51 mm
Dan -
07-03-2013, 11:01 PM
Post: #46
ditn Wrote:janspeed bigbore but in mild steel... 58mm bore
I've red on a few forums that those mild steel exhausts rust pretty fast.
ハチロク
07-04-2013, 07:45 PM
Post: #47
^Yup. I bought an hks sport new which is mild steel with high temp paint. It started showing some signs of surface rust on the welds after only a year, and I live in a very dry desert climate.
07-06-2013, 12:04 PM
Post: #48
Project D Wrote:OEM exhaust (map version, so without the catalytic converter) = 92dB
92dB? On my Papers, no catalytic converter swiss spec AE86, i got only 77dB
Daily Beater: Civic EG5
Work in progress Car: AE86
07-22-2013, 04:09 PM
Post: #49
Lucky you my original Swiss papers say 75/76dB. Also non Cat version
  Help me to finish!!! Allexz 9 7,835 02-10-2008 05:26 AM
Last Post: parrot
