Finish Exhaust Martelius
07-03-2013, 12:50 PM
Post: #41
i checked brave before,and i didnt spot a middle damper(pot? how is it called in english),thats why i skipped the exhaust system.
also the exhaust db is 95db so probably bit more and then i cant drive on zolder. |
07-03-2013, 12:57 PM
Post: #42
OEM exhaust (map version, so without the catalytic converter) = 92dB
I hardly believe that ANY custom exhaust would make you able to stay under 93dB |
07-03-2013, 07:55 PM
Post: #43
Ow shit i made an error on the db its 95db in stead of 93db
so if you could chose for 4AGZE ae101 which one would you chose janspeed bigbore but in mild steel... 58mm bore Martelius 51 mm brave but i think it has a cat,im very against cat |
07-03-2013, 09:28 PM
Post: #44
ditn Wrote:Ow shit i made an error on the db its 95db in stead of 93db No cat... mid length resonator, and muffler Dan - You can | .... OR you can ask for help!!! OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
07-03-2013, 09:29 PM
Post: #45
07-03-2013, 11:01 PM
Post: #46
ditn Wrote:janspeed bigbore but in mild steel... 58mm bore I've red on a few forums that those mild steel exhausts rust pretty fast. ハチロク |
07-04-2013, 07:45 PM
Post: #47
^Yup. I bought an hks sport new which is mild steel with high temp paint. It started showing some signs of surface rust on the welds after only a year, and I live in a very dry desert climate.
07-06-2013, 12:04 PM
Post: #48
Project D Wrote:OEM exhaust (map version, so without the catalytic converter) = 92dB 92dB? On my Papers, no catalytic converter swiss spec AE86, i got only 77dB Daily Beater: Civic EG5 Work in progress Car: AE86 |
07-22-2013, 04:09 PM
Post: #49
Lucky you my original Swiss papers say 75/76dB. Also non Cat version
AE86 ex-daily |
Help me to finish!!! | Allexz | 9 | 7,835 |
02-10-2008 05:26 AM Last Post: parrot |
