Fitting camber plates on shocks with odd threaded nuts
10-17-2007, 07:45 AM
Doc, did you put some sort of bush inside the camber plate? the shaft of the koni isn't big enough is it?
10-17-2007, 08:24 AM
For the record / search function:
The same problem applies to camber plates paired with TRD Blue adjustable shocks.
I used the stock nuts for the first ~4 months and encountered a horrible clonking noise that I couldn't allocate at first.
Turns out I also couldn't tighten the nut on the camber plate correctly, so it had play.
Use deep-type nuts for your upper mounts. Wink
10-17-2007, 09:43 AM
http://www.aeu86.org/viewtopic/which-cam...highlight=
10-17-2007, 11:40 AM
Mux213 Wrote:Doc, did you put some sort of bush inside the camber plate? the shaft of the koni isn't big enough is it?
no, i only use the stock koni nut Tongue
And my suspension is completely quiet Smile
10-17-2007, 12:47 PM
AshCampbell Wrote:http://www.aeu86.org/viewtopic/which-cam...highlight=
Hahah, proves even an admin can create a double topic Smile
Thanks Ash, will look into merging these topics.
  Fitting Air Con (No PS) to LHD AE86 pack 7 4,590 01-07-2024 11:36 AM
Last Post: CCB
  Fitting Fibreglass Kouki Lip? chrisae86 3 2,321 02-25-2022 08:14 PM
Last Post: chrisae86
  rear bilstein B6 shocks 2 types what to choose? Ryo 5 3,690 07-25-2021 04:41 AM
  KONI Sports shocks for the AE86... jondee86 11 21,361 09-08-2017 03:38 AM
Last Post: jondee86
  Fitting driftworks CS2 coilovers bozu 2 4,934 05-30-2017 10:50 AM
Last Post: bozu
