Floor mat options in a track car
05-30-2010, 07:51 AM
Seems silly but... what options are out there that fit the AE86 chassis? I dont really want to hear my clutch pedal hit metal every time I shift gears.
05-30-2010, 10:42 AM
Glue some rubber to the back of the pedal?
05-30-2010, 10:50 AM
Not mats but Ive seen carbon fibre & checker plate versions.
here is an example, prob very expensive with the $ conversion
http://www.galwaycarbon.com/car-parts/ae86-corolla/
05-30-2010, 11:11 AM
Those are some nice parts there...
I was thinking a rubber stop might be the best solution, but I also like the idea of protecting the paint in a high wear zone around the feet.
05-30-2010, 11:16 AM
I would have thought that a mat would be the last thing that you would want floating around under your feet , if it isn't screwed or bolted down forget it .
Keep your original molded carpet or make some thing out of aluminum plate .I wouldn't have thought the clutch pedal should be going all the way to the floor ?
Just my 2 cents worth .
Your addiction to motorsport can only be cured by poverty !!
  Wide Track 86 Mylesmck 8 2,772 05-28-2023 09:51 PM
Thumbs Up ITB filter options mister86 1 3,633 12-06-2020 10:44 AM
  AE86 starter options max_ae86 12 31,428 07-28-2019 08:17 PM
Last Post: harkes
  AE86 rear suspension options 2018 Alex 9 11,599 01-24-2018 02:25 PM
  Rear axle options Dino86 13 13,673 01-08-2018 10:19 PM
Last Post: ditn
