From the USA: Dropping a 4AGE engine in a stock SR5
03-23-2008, 06:22 AM
Background: I got this car for 500 USD. Came with a GTS transmission and a car battery as well as GTS fuel pump and GTS engine wiring harness. Car is not running and is missing a ton of stuff from the engine. However, it did come with a 4AGE engine.
[img name=]http://www.aeu86.org/files/ds/dsc04984_359.jpg[/img]
[img name=]http://www.aeu86.org/files/ds/dsc04985_198.jpg[/img]
[img name=]http://www.aeu86.org/files/ds/dsc04986_482.jpg[/img]
[img name=]http://www.aeu86.org/files/ds/dsc04987_161.jpg[/img]
[img name=]http://www.aeu86.org/files/ds/dsc04988_413.jpg[/img]
Wiring Harness
[img name=]http://www.aeu86.org/files/ds/dsc04994_634.jpg[/img]
GTS transmission
[img name=]http://www.aeu86.org/files/ds/dsc04992_131.jpg[/img]
Anyways I have ordered the AFM, Airbox, Hose, and Filter as well as an exhaust manifold. What do you guys suggest as the mode of operation? What would I do just to get the car running. Also there is an MR2 in the junkyard: what can I use from that?
Thanks!
03-25-2008, 08:22 AM
Some pics of the car. Engine pics coming tomorrow.
[img name=]http://www.aeu86.org/files/ds/dsc05017_163.jpg[/img]
[img name=]http://www.aeu86.org/files/ds/dsc05016_181.jpg[/img]
[img name=]http://www.aeu86.org/files/ds/dsc05018_145.jpg[/img]
[img name=]http://www.aeu86.org/files/ds/dsc05021_378.jpg[/img]
Big Question: Which of these parts from MR2 will work in 4AGE AE86
Igniter/Coil
Fusible Link Box on positive battery terminal
Exhaust Manifold
GTS Fuel Lines
O2 sensor
Major thanks to all who have helped me on this forums!!
03-25-2008, 09:41 AM
Resized your images (most of them were bigger than 1MB) and attached them since it took ages to open this topic. Wink
[Image: AEU86 AE86 - From the USA: Dropping a 4A... stock SR5]
03-25-2008, 09:54 AM
Thats not a bad deal, looks like a nice bit of work though.
Note that you're missing the water pump pully and mechanical fan, and I don't see an alternator. Probably you can get at least some of these parts from the MR2 if its a 4AG powered AW11. Good excuse also to go for an electrical fan.
Not sure if you could use the total radiator and fan assembly of an AW11, its probably sized differently.
I also do not see an oil cooler, you may need to source those parts or go for a better aftermarket one though that would be overkill Smile
03-26-2008, 07:38 AM
Ive got the Alternator/Belt system, Water Pump Pulley, and Mechanical Fan in the trunk. Getting a radiator too. Just not assembled yet (missing the bolts for the alternator)...
3/8" bolt for alternator
exhaust manifold
coil/ignitor
coolant tank
fusible link box
fuel lines
throttle cable (93 toyota tercel should work)
Oxygen Sensor
Filter for Airbox
Drivers side door Panel
Dashboard
Top of the Backseat Right Side
Brakeline to Engine hose and female plug
GTS fuel filter
Clutch Line
Plastic Horn Cover
List of parts needed so far: probably missing a few too Wink
Going to local junkyard tomorrow to pull them out of cars. Then we shall piece it together. Pics coming in tomorrow or day after. Sorry about the large image size.
03-28-2008, 10:52 AM
We have experienced a huge wiring crisis here. We have received very low voltage to some of our connections and am missing a bunch of wiring parts. Please tell me if you see any wiring missing from the pictures you see.
I have decided to host this on my server in a neat html page. I just thought that would be easier...
Here is the link:
http://76.192.130.86/ae86.html
Any help is greatly appreciated!!!
03-28-2008, 06:42 PM
so today we decided to test if the starter is working: it is. IT is just not receiving power from that little black plug hooked to the starter (terminal 50). When we turn the ignition no power comes to the plug. Also the circuit open relay clicks loudly on ignition--unfortunately nothing else happens.
What are some possible troubleshooting steps. Could somebody please look at our wiring and comment?
Thanks very much!
  Racecar: TRD USA built ITA AE86 oldeskewltoy 38 42,945 07-22-2019 02:55 PM
Last Post: apardal
  1986 Corolla SR5 S2k Build.... MIami style geoscranny84 16 22,461 04-26-2012 08:00 PM
Last Post: [Walaki]D`Lair
  1987 sr5 project purplerain11 3 6,291 04-15-2012 03:34 AM
Last Post: purplerain11
  My SR5 to GTS Restoration Conversion. Lofty 15 19,802 09-25-2009 06:52 AM
Last Post: Lofty
  AE86 Trueno Coupe (SR5-GTS)//Sweden Allexz 71 75,375 03-16-2009 10:02 PM
