Front End Brake Work
01-02-2009, 07:01 AM
Took my AE86 too a local mechanic, they told me it would be $800 to do the work. I figured I might as well do it myself as I could get the parts for around $200.
Needs: Calipers Pads Rotors I've never done this before, can you guys give me help on what I should do. Thanks |
01-02-2009, 08:45 AM
88rotors.com for the disks & pads, take off you calipers & get them re-conditioned, kits are available from Toyota if you fancy a go, but Id leave it to someone with experience if you are a novice.
01-02-2009, 05:42 PM
Re-Conditioned?
I was talking with a parts store earlier and they said they could give me 2 Calipers for $90. However the garage I went to said they were going to re-condition the ones I had for $80 a peice. Somehow the diference in price doesnt sound right to me. Any Ideas? |
01-02-2009, 05:51 PM
For $90 see what happens, hard to figure that price out.
Go get em & report back An 86 is for Life, not just for Christmas |
01-02-2009, 06:01 PM
What kind of Tools do you need to change the parts to begin with?
I would assume a Socket set but a friend mentioned some cars require a special socket, is this the case with the AE86. |
01-02-2009, 06:57 PM
Socket set & spanners, G Clamp to replace the pads when you get the Calipers sorted.
20v mains & big end bearing | izanagi | 9 | 10,566 |
12-26-2016 12:42 PM Last Post: pack |
Front big brake kit | DidiDex | 14 | 18,981 |
10-24-2016 09:29 AM Last Post: FanIsHere |
How seatbelt rails work? | FanIsHere | 2 | 4,726 |
05-18-2016 09:52 AM Last Post: Bean |
S13 rear end project underway | 4000GT | 23 | 28,251 |
07-26-2013 09:54 AM Last Post: 4000GT |
Gear end , drive pinion height | filh | 5 | 11,350 |
06-27-2013 12:29 AM Last Post: filh |
