Front end roof compatibility between 2dr and 3dr
12-05-2013, 10:14 PM
Hi,
I'd like to ask if i can fit a 2dr(coupe) roof to a 3dr (hatch), i just care about the front end , the 2 pillows or bridges that connect the roof to the body... Are they compatible? Thanks |
12-05-2013, 10:37 PM
I think they are the same apart from the rear (C-pillar?)
12-06-2013, 01:58 AM
Ivan141 Wrote:I think they are the same apart from the rear (C-pillar?)Thanks mate ![]() So the A & B pillars are the same ? |
12-06-2013, 03:18 AM
yes
12-06-2013, 09:47 PM
A pilar is the same but not sure for the B pilar.
The rear window of the 2dr is "flush" to the door but there is a peace of "metal shhet" between the rear window and the door on the 3dr (but the roof is perhaps compatible) |
12-06-2013, 09:48 PM
i think it don't fit.
rear window are not the same so the shape around it will not fit. SR Team BURN THE RUBER NOT YOUR SOUL! |
12-06-2013, 11:25 PM
BOOMEX Wrote:i think it don't fit.I'll use the front end of it and weld it the the original rear end |
12-07-2013, 04:30 AM
Dochka Wrote:BOOMEX Wrote:i think it don't fit.I'll use the front end of it and weld it the the original rear end Good luck with that, you trying to get rid of a sunroof? 1979 Toyota Corolla KE35 1983 Toyota Corolla AE86 1985 Toyota Corolla AE86 |
12-07-2013, 11:02 AM
Dochka Wrote:BOOMEX Wrote:i think it don't fit.I'll use the front end of it and weld it the the original rear end Good luck with that. if you done it please post a lot of pics of the prep and the welding. Thanks. SR Team BURN THE RUBER NOT YOUR SOUL! |
01-12-2014, 04:29 PM
Are the doors compatible ?
| AE86 front end conversion Levin -> Trueno Electronics. | gh0st | 3 | 9,571 |
07-17-2021 11:20 PM Last Post: banpei |
| OST-039: The end of the beginning.... | oldeskewltoy | 10 | 15,675 |
11-11-2016 09:52 PM Last Post: oldeskewltoy |
| 2dr levin 86 | ssr86 | 7 | 11,508 |
10-21-2011 08:34 PM Last Post: ssr86 |
