Front fender (wing)
02-09-2008, 08:59 PM
Front fender (wing)
I need to remove the front fender from my car, can someone who has done it before give me a few tips.
It looks fairly straightforward but I'm not sure what holds it on at the bottom. Thanks An analogue brain in a digital World |
02-09-2008, 09:09 PM
Front fender (wing)
Front wing???
Remove the front indicator (screwdriver), undo the line of 10mm bolts along the top of the wing in the enginebay, theres 2 beside the door hinges, be careful not to remove paint off the door, & there are 2 behind the arch on the sill which usually break off once disturbed An 86 is for Life, not just for Christmas |
02-09-2008, 09:40 PM
Front fender (wing)
Thankyou for a quick reply.
If the two break off what are the re-fitting options ? An analogue brain in a digital World |
02-09-2008, 09:54 PM
Front fender (wing)
See how you get on, If the wing is rotten but the sill is good its not so bad, Ive even bonded the wing onto this area before.
| Can Wing Mirror Glass be Replaced? | chrisae86 | 4 | 2,638 |
10-05-2025 11:09 PM Last Post: chrisae86 |
| Converting Jap Spec wing mirrors to UK spec | chrisae86 | 5 | 3,996 |
04-12-2022 11:03 PM Last Post: chrisae86 |
| GT Wing options | 4000GT | 10 | 23,940 |
06-19-2014 07:34 AM Last Post: 4000GT |
| Question: Where I can find this fender flare? | winchi.c | 3 | 6,119 |
05-01-2011 09:58 AM Last Post: Bentley |
| fender holes measure HELP | sergiocharged | 11 | 13,720 |
12-24-2010 04:08 PM Last Post: aussiefan |
