my bluetop 4a-ge won't start HELP
07-04-2013, 05:57 PM
Got some seriuos problems.
Thing is my hachiroku atm is stored in dry garage, fired up like every week or two. Everyting was fine to last week, i just came up wanted to take it for a ride, but pretty much my 4 pistons just made a cough and then noting even a one beat. Up to date checked: -nice and big spark -fuel pump is running as a hear it after every single attempt it does build initial pressure in the system. -new distributor cap plugs and wires (was working on this set) Engine is fairly stock utillises only fuel pres reg from red top which is if i remember right like 3 bar instead of 2.5 bar I have no clue, i have checked all connections preety much HELP!!! we ride together we die together |
07-04-2013, 06:16 PM
Try with another battery
07-04-2013, 06:23 PM
battery is working fine cranking up well
if that would be ecu issue then fuel pump wouldn't work or there would be no spark am i right? I'm a bit disapointed about the fact because she never let me down up to now. we ride together we die together |
07-04-2013, 06:41 PM
Does the startermotor work properly?
ハチロク ![]() |
07-04-2013, 10:00 PM
yea all ancilaries are working fine at least were, finally after work today i have found out that plug for air/fuel mixture regulator was loose just a bit, so it was tricky to see if it connects inside.
plugged in and legend about toyotas reliability is still alive ![]() we ride together we die together |
Refreshed 20v blacktop first start.. | Mylesmck | 6 | 1,128 |
Warm start problem | DJexor | 5 | 2,633 |
03-09-2023 10:15 AM Last Post: Ivan141 |
Bluetop Engine Rebuild multiple question Goal 150-160hp | Hanzo | 16 | 10,343 |
Newb question on "how-to" guide for ITBs on JDM 4AG Bluetop w/ MAP | mister86 | 12 | 11,903 |
Weak spark, doesn’t start. | AlexFourTwenty | 4 | 16,095 |
