Fuel Catch Tank sugestion
09-08-2005, 04:48 PM
How to make Fuel Catch Tank, where to locate it, pipes, rails sugestion...pic posible, links allso
Does it help to make central fuel tank behind front seats?
Anyone make it, buy somewhere??
tnx
[Image: AEU86 AE86 - Fuel Catch Tank sugestion]
09-08-2005, 05:14 PM
KristianAE86 got one himself:
http://www.aeu86.org/viewtopic.php?t=138...catch+tank
Perhaps he can give you directions.
09-08-2005, 10:14 PM
We have some drawings in one of the other threads about the surge tank. Its really not that hard to make if you know what its supposed to do... So do some searchingSmile
09-08-2005, 10:30 PM
You need ideally a 2ltr+ tank.
At the bottom take a feed off to supply your engine fuel pump, at the top you will need a return line from the fuel rail. You will need another at the top for the return line from surge tank to the fuel tank for overflow. Another feed at the top for the lifter pump from fuel tank to surge tank, this can be a low pressure affair.
09-09-2005, 01:50 AM
BenR Wrote:You need ideally a 2ltr+ tank.
Ben...
why 2litres + ?
i have 1,2 litre
i belive that an HKS tank for the Supra mk4 is for 1 litre
09-09-2005, 02:30 AM
just incase.....better to have too much in store than too little.
many people run smaller, but for no extra effort, i dont see why not 2ltr.
  bubbles in expansion tank? fax0815 5 6,139 04-28-2017 04:57 PM
Last Post: fax0815
  Fuel Tank Modification apardal 1 5,635 08-11-2014 06:59 PM
  Pressure gathering in fuel tank Apolan 9 15,373 05-18-2014 06:18 AM
Last Post: chenfon
  plastic fuel tank bakonick 12 13,120 12-26-2012 12:08 AM
Last Post: bakonick
  oil catch can/ suspension question fax0815 12 17,137 04-23-2011 01:31 AM
Last Post: jondee86
