Fuel Pressure regulator
03-03-2005, 05:39 PM
@ nmwisima:
I was outside to take a walk with my daughter :-)
http://www.billzilla.org/4agstock3.htm
Quote:One last important item is the small rubber pipe that goes from the inlet manifold to the fuel pressure regulator. What it does is this - When there's a high vacuum, as you get at idle, it alters the regulator so that it has a little less pressure. When you open the throttle, the manifold pressure quickly rises a little, and as a result the fuel pressure also rises a little, thus making a cheap & effective accelerator pump. The engine will work just fine without that rubber pipe though.
This is interesting explanation about "2.2 bar pressure at idle" case.
Quote:oem gZe running at 0,55 bar boost and about 2,5 bar fuel pressure at idle, right?
I use a larger pulley, STi pump (240 lit/hour) and fuel pressure regulator and run 0,86 bar boost with 3 bar f.p.
When GZE engine idles - the fuel pressure will be again 2.2 bar (because of VAC). When GZE runs 0.55 bar boost - the fuel pressure will be somewhere 3.05 bar (if we measure 2.5 bar on NA engine + boost pressure). The main ideia is to increase injector flow via fuel pressure instead of injector size. This can be done in limited (~10-15%) borders. So in described situation if we run idle at 2.5 bar instead of 2.2, NA will be 2.8 and boosted - 3.35 bar.
PS:4AGZE uses electic supercharger clutch and some electric air valves but I'm not sure about electric valve for fuel pressure regulator - I just haven't info about this regulator from GZE engine.
Messages In This Thread
Fuel Pressure regulator - filh - 03-02-2005, 06:15 PM
[] - Ivan141 - 03-02-2005, 06:46 PM
[] - jamiemirror - 03-02-2005, 10:11 PM
[] - filh - 03-03-2005, 12:39 AM
[] - jamiemirror - 03-03-2005, 12:49 AM
[] - filh - 03-03-2005, 02:08 AM
[] - jamiemirror - 03-03-2005, 12:57 PM
[] - nmwisima - 03-03-2005, 01:07 PM
[] - jamiemirror - 03-03-2005, 01:30 PM
[] - filh - 03-03-2005, 02:22 PM
[] - jamiemirror - 03-03-2005, 02:32 PM
[] - Mux213 - 03-03-2005, 02:32 PM
[] - nmwisima - 03-03-2005, 02:47 PM
[] - nmwisima - 03-03-2005, 03:09 PM
[] - jamiemirror - 03-03-2005 05:39 PM
[] - nmwisima - 03-03-2005, 06:26 PM
[] - filh - 03-04-2005, 07:19 PM
[] - alimonos - 03-04-2005, 10:59 PM
[] - jamiemirror - 03-04-2005, 11:16 PM
[] - NoHachi - 03-04-2005, 11:23 PM
[] - jamiemirror - 03-04-2005, 11:34 PM
[] - NoHachi - 03-05-2005, 02:49 AM
[] - filh - 03-05-2005, 05:29 PM
[] - jamiemirror - 03-05-2005, 05:39 PM
[] - alimonos - 03-06-2005, 01:03 AM
[] - jamiemirror - 03-06-2005, 06:11 PM
[] - nmwisima - 03-09-2005, 02:09 PM
[] - cj - 03-25-2005, 07:37 PM
[] - filh - 05-06-2005, 08:29 PM
[] - NoHachi - 05-06-2005, 09:59 PM
[] - filh - 05-07-2005, 11:06 PM
[] - Ivan141 - 05-08-2005, 10:49 AM
[] - filh - 05-08-2005, 08:08 PM
[] - jamiemirror - 05-09-2005, 12:47 PM
[] - filh - 05-09-2005, 07:58 PM
  Build your own adjustable fuel pressure regulator ;) oldeskewltoy 8 21,258 08-19-2018 12:08 PM
Last Post: AlexKTM
  4AGE Fuel Regulator Alex170984 6 10,283 02-24-2016 05:59 PM
Last Post: totta Crolla
  Oil Pressure Query Alex170984 2 5,229 12-11-2014 01:25 AM
Last Post: Alex170984
  Pressure gathering in fuel tank Apolan 9 15,041 05-18-2014 06:18 AM
Last Post: chenfon
  oil pressure high kawo 17 20,664 09-29-2013 12:06 PM
Last Post: allencr
