Fuel Pump wiring
05-22-2008, 06:36 AM
Fuel Pump wiring
Does anybody know how to wire the fuel pump to the car without a GTS rear harness?
I have an SR5 rear harness.
Thanks
05-22-2008, 07:24 AM
Fuel Pump wiring
plus from ignition key to pump. pump to ground.
DonĀ“t Think About The Past,
Live In The Present And
Dream About Tomorrow
05-24-2008, 06:17 AM
Fuel Pump wiring
Great. Thanks.
Im sure we can figure it out, but if anybody knows off hand: where do we wire the plus to specifically on the ignition switch?
05-24-2008, 07:12 AM
Fuel Pump wiring
The fuel pump only adds one wire to the SR5 rear harness.
If you follow the EWD diagrams it is really easy.
http://www.aeu86.org/index/technical-ae8...topic=5158
Do it properly with a circuit open relay, which you can pickup up from any 80's EFI Toyota at the wreckers. Don't forget to grab the plug with a fair bit of wire, then join as required.
  Tail light wiring... Mylesmck 4 934 02-02-2024 12:36 PM
Last Post: Mylesmck
  20v BT - which oil pump? Mylesmck 4 2,621 06-21-2022 04:51 PM
Last Post: pack
  Lambda sensor wiring sam3007 10 4,257 05-23-2022 10:00 PM
Last Post: The Doctor
  Fuel pump issue DJexor 11 4,919 04-29-2022 05:45 AM
  4A-GE wiring engine to chassis connectors Lykowsky 4 6,854 06-20-2019 11:38 AM
Last Post: Lykowsky
