Fuel gauge: works but shows lower than real??
10-21-2005, 10:00 AM
Hi,
I tried a search because back in the days there were lots of questions about the AE86 fuel gauge, but I couldnt find anything...
Here's the deal: when I fill up to top, my fuel gauge will only go up to 3/4, I know that it takes time to go up, but it wont go past 3/4 of the scale...
Then it goes down and when the gauge shows empty, I fill up like 30 liters, and the warning light doesn't come on....
The car has been fully rebuilt and therefore been sitting for the last 4 years, I cant remember that the gauge wasnt working before, is it the sender that is shot? Or is the gauge itself shot? or might there be a resistance at some connection causing the gauge to show lower than it should?
Thanks a lot
Patrick
10-21-2005, 10:30 AM
Same problem here. Can anybody help?
10-21-2005, 10:50 AM
Mine will go all the way up, but after driven 50 kilometers it is already at 3/4th and slowly going to 1/2 within another 50 kilometers. After that it stays there till I've driven another 200 kilometers and then going down again. Really confusing... Confused
[Image: AEU86 AE86 - Fuel gauge: works but shows...han real??]
10-21-2005, 10:53 AM
exact the same problem in my coupe. tank shows empty i fill it with cca 30 liters, until the cap. and the gauge shows 3/4.after pair of km of driving it shows 1/2.
http://www.86ers.org
10-21-2005, 11:45 AM
The part inside the tank must be replaced!
If you leave your car for a long time with half tank filled, seems that something "rusts" inside the tank level meter and is not sliding well.
Usually here is the problem.
http://www.ae86.gr
10-21-2005, 01:10 PM
How many liters are our tanks by the way?
10-21-2005, 01:26 PM
LOL!
I've got 2 86's with the same problem! Tongue
10-21-2005, 01:51 PM
same prob but i pay mine no attention cause if im short on money and on E i can still drive
10-21-2005, 01:56 PM
I think its a common problem amongst Toyota's. My brothers SW20 has a similar issue but not quite as drastic. It just slows down when he gets to half a tank. I always fill up at quarter of a tank myself so im not concerned by it.
10-21-2005, 02:00 PM
@Euripides: I had my fuel tank open to replace the fuel pump bracket, and the tank is shiny as new inside, not a single spot of rust.... I didnt check the level sensor arm mechanism tho... does anyone know if I can take the whole thing out without dropping the tank? (FYI: fuel pump cannot)
Thx!
  EUDM gauge cluster banpei 22 5,685 08-15-2023 10:48 PM
  Engine starts/revs but no idle GenkiMotors 17 8,251 11-20-2021 04:12 AM
Last Post: GenkiMotors
  4age 16v running roughly - diagnostics shows unknown code Ryo 8 8,026 11-09-2020 10:51 AM
Last Post: totta Crolla
  Water Temperature Instrument not moving - Sender Gauge Hama86 8 8,098 12-06-2017 06:48 PM
  cool lower radiator hose thanos 4 5,775 11-29-2016 01:06 PM
Last Post: thanos
