Fuel gauge: works but shows lower than real??
10-21-2005, 10:00 AM
Hi,
I tried a search because back in the days there were lots of questions about the AE86 fuel gauge, but I couldnt find anything... Here's the deal: when I fill up to top, my fuel gauge will only go up to 3/4, I know that it takes time to go up, but it wont go past 3/4 of the scale... Then it goes down and when the gauge shows empty, I fill up like 30 liters, and the warning light doesn't come on.... The car has been fully rebuilt and therefore been sitting for the last 4 years, I cant remember that the gauge wasnt working before, is it the sender that is shot? Or is the gauge itself shot? or might there be a resistance at some connection causing the gauge to show lower than it should? Thanks a lot Patrick |
10-21-2005, 10:30 AM
Same problem here. Can anybody help?
10-21-2005, 10:50 AM
Mine will go all the way up, but after driven 50 kilometers it is already at 3/4th and slowly going to 1/2 within another 50 kilometers. After that it stays there till I've driven another 200 kilometers and then going down again. Really confusing...
10-21-2005, 10:53 AM
exact the same problem in my coupe. tank shows empty i fill it with cca 30 liters, until the cap. and the gauge shows 3/4.after pair of km of driving it shows 1/2.
http://www.86ers.org All the hachies that Daytona can only dream about. |
10-21-2005, 11:45 AM
The part inside the tank must be replaced!
If you leave your car for a long time with half tank filled, seems that something "rusts" inside the tank level meter and is not sliding well. Usually here is the problem. ![]() http://www.ae86.gr |
10-21-2005, 01:10 PM
How many liters are our tanks by the way?
AE86 FANATIC!!! |
10-21-2005, 01:26 PM
LOL!
I've got 2 86's with the same problem! ![]() Why motorsports? Because other sports require only one ball! |
10-21-2005, 01:51 PM
same prob but i pay mine no attention cause if im short on money and on E i can still drive
10-21-2005, 01:56 PM
I think its a common problem amongst Toyota's. My brothers SW20 has a similar issue but not quite as drastic. It just slows down when he gets to half a tank. I always fill up at quarter of a tank myself so im not concerned by it.
10-21-2005, 02:00 PM
@Euripides: I had my fuel tank open to replace the fuel pump bracket, and the tank is shiny as new inside, not a single spot of rust.... I didnt check the level sensor arm mechanism tho... does anyone know if I can take the whole thing out without dropping the tank? (FYI: fuel pump cannot)
Thx! |
EUDM gauge cluster | banpei | 22 | 5,634 |
08-15-2023 10:48 PM Last Post: banpei |
Engine starts/revs but no idle | GenkiMotors | 17 | 8,191 |
11-20-2021 04:12 AM Last Post: GenkiMotors |
4age 16v running roughly - diagnostics shows unknown code | Ryo | 8 | 7,934 |
Water Temperature Instrument not moving - Sender Gauge | Hama86 | 8 | 8,040 |
12-06-2017 06:48 PM Last Post: Bean |
cool lower radiator hose | thanos | 4 | 5,749 |
