Fuel help please!
01-16-2009, 11:41 PM
Fuel help please!
I am getting fuel starvation.
Here is my set-up: Walbro 255 pump 20 valve Blacktop stock gts fuel lines stock gts tank Here is whats happening: It started that the fuel would cut at high RPM's, or around corners. I tried a fuel system cleaner but it basically shut the system down. I also changed the fuel filter up under the bonnet. Then I bought a new strainer/ filter for the fuel pump. The car ran strong around the block, but then went back to basically less than a limp mode. I was sure it was a combo of a dirty tank, and bad fuel pump. So today I bought the walbro, pressure washed the tank, and put all new gas in. It worked great, for about 5 minutes and back to where we started. The car idols just fine but is just dying under any strain at all. I guess that since I ran maybe 10 miles since i changed the fuel filter maybe all that bad gas clogged it back up? I suppose the fuel lines maybe are clogged as well? I am really kinda stumped at this point. Any ideas? |
01-17-2009, 04:53 AM
Fuel help please!
Pull the return line after the regulator and run the open end into some
sort of a container with a spare piece of hose. Crank the engine. Fuel should come out of the open end like a fire hose !!!! If there is just a weak flow, you have a restriction somewhere, and you have to work backwards thru the pipework until you find it. Cheers... jondee86 |
01-17-2009, 11:21 PM
Fuel help please!
jondee86 Wrote:Pull the return line after the regulator and run the open end into some thanks. I will be doing a lot of guess and check this next week! fun. |
TUV RHD AE86 Germany (help please) | 4dori | 9 | 7,451 |
07-17-2019 07:42 PM Last Post: Hachigo83 |
Carb question please help | MIGGZFSU | 3 | 4,916 |
03-29-2017 03:06 PM Last Post: MIGGZFSU |
Whining noise HELP PLEASE | izanagi | 10 | 12,808 |
03-26-2015 06:48 PM Last Post: Komba |
the connector saga (please help everyone) | Bean | 8 | 9,615 |
06-23-2014 01:13 PM Last Post: Bean |
AE 101 - 111 ITB Question, please help | ZDoman | 12 | 15,243 |
02-03-2013 09:39 PM Last Post: banpei |
