Fuel help please!
01-16-2009, 11:41 PM
Fuel help please!
I am getting fuel starvation.
Here is my set-up:
Walbro 255 pump
20 valve Blacktop
stock gts fuel lines
stock gts tank
Here is whats happening:
It started that the fuel would cut at high RPM's, or around corners. I tried a fuel system cleaner but it basically shut the system down. I also changed the fuel filter up under the bonnet. Then I bought a new strainer/ filter for the fuel pump. The car ran strong around the block, but then went back to basically less than a limp mode. I was sure it was a combo of a dirty tank, and bad fuel pump. So today I bought the walbro, pressure washed the tank, and put all new gas in. It worked great, for about 5 minutes and back to where we started. The car idols just fine but is just dying under any strain at all.
I guess that since I ran maybe 10 miles since i changed the fuel filter maybe all that bad gas clogged it back up? I suppose the fuel lines maybe are clogged as well?
I am really kinda stumped at this point. Any ideas?
01-17-2009, 04:53 AM
Fuel help please!
Pull the return line after the regulator and run the open end into some
sort of a container with a spare piece of hose. Crank the engine. Fuel
should come out of the open end like a fire hose !!!!
If there is just a weak flow, you have a restriction somewhere, and you
have to work backwards thru the pipework until you find it.
Cheers... jondee86
01-17-2009, 11:21 PM
Fuel help please!
jondee86 Wrote:Pull the return line after the regulator and run the open end into some
Cheers... jondee86
thanks. I will be doing a lot of guess and check this next week! fun.
  TUV RHD AE86 Germany (help please) 4dori 9 7,098 07-17-2019 07:42 PM
Last Post: Hachigo83
  Carb question please help MIGGZFSU 3 4,743 03-29-2017 03:06 PM
Last Post: MIGGZFSU
  Whining noise HELP PLEASE izanagi 10 12,329 03-26-2015 06:48 PM
Last Post: Komba
  the connector saga (please help everyone) Bean 8 9,223 06-23-2014 01:13 PM
  AE 101 - 111 ITB Question, please help ZDoman 12 14,711 02-03-2013 09:39 PM
