Fuel pump issue
04-28-2022, 11:30 AM
Fuel pump issue
it at least does not fire at all, what iff you use brake cleaner in the inlet? did you tried that? iff it then doesnt want to get going or has the intention, is is a electric supply issue. else fuel I would say
Gtsi-R "Trust me, I was an engineer" "straight lines are for fast cars, turns are for fast drivers" |
04-29-2022, 05:45 AM
(This post was last modified: 04-29-2022 05:47 AM by Bean.)
Fuel pump issue
Fuel smell could potentially be only from the cold start injector. You can unplug it and see/listen/smell if the behaviour is different.
AE86 ex-daily |
PWR light issue and no brake fluid after winter storage | magpie | 10 | 3,131 |
20v BT - which oil pump? | Mylesmck | 4 | 3,025 |
Clutch Issue | Deaty | 8 | 4,638 |
04-09-2021 10:26 PM Last Post: Nakilad |
5th gear issue | r.ave | 1 | 2,739 |
03-14-2021 08:52 PM Last Post: Ivan141 |
exhaust odor/idle MOT issue | Ryo | 7 | 7,729 |
