Fuel surge tank
06-30-2005, 10:14 AM
Fuel surge tank
Denmark Wrote:Knudsen,I need it welded in Stainless,i got a 4inch pipe from when i made a ´downpipe for the Impreza,so i need 2 endplates ø100mm,and 4 pipes ,that are 8mm outside.
regards,
Skassa
Thats easily made, just give me a call and ill se what i can do :wink:
06-30-2005, 11:32 AM
Fuel surge tank
Knudsen,I will call you later today.
I have a Impreza intank fuelpump now,and i will use a new bosch extern inline pump from the surge tank,
It will not cost much to make this eighter,the most expensive parts are the fuelhose,i will make it so it can sit to the left of the sparewheel well.
"""www.turbotoys.dk"""
07-01-2005, 10:03 PM
Fuel surge tank
Kristian,
Are you sure that ,that´s the reasen why your pump brok?.
I´m just thinking,why is there need for a filter between the OE tank and the surgetank, when there is a filter in the tank(on the OE pump)
I just got a brand new Bosch pump,and i don´t what to ruin it,but i just don´t understand the need of this,can you plz explain
Regards,
Skassa
07-01-2005, 11:44 PM
Fuel surge tank
I could only see the need of an extra, if the surgetank is full of crap... Skassa, yours gonna be fine on the inside, cant se why there shold be reason for an extra filter.
07-03-2005, 10:12 PM
Fuel surge tank
Denmark Wrote:Kristian,
Regards,
Skassa
i was told to use an extra filter between tank & pump because i have an externaly mounted surgetank-pump.
So i will.
It only costs like 10 E anyways
07-04-2005, 09:48 AM
Fuel surge tank
It´s now made and mounted, and it´s working perfect,even when the low fuel lamp is on,i can still drive like a maniac Smile
Thanks,
Skassa
07-04-2005, 11:26 AM
Fuel surge tank
Denmark Wrote:It´s now made and mounted, and it´s working perfect,even when the low fuel lamp is on,i can still drive like a maniac Smile
Thanks,
Skassa
pics of how you mounted it please
07-04-2005, 09:43 PM
Fuel surge tank
pics.[Image: AEU86 AE86 - Fuel surge tank]
[Image: AEU86 AE86 - Fuel surge tank][/img]
07-04-2005, 11:11 PM
Fuel surge tank
That looks pro! As always Thumbs up!
07-05-2005, 09:28 AM
Fuel surge tank
whoa very nice indeed total cost ???
  bubbles in expansion tank? fax0815 5 5,800 04-28-2017 04:57 PM
Last Post: fax0815
  Fuel Tank Modification apardal 1 5,450 08-11-2014 06:59 PM
  Pressure gathering in fuel tank Apolan 9 14,786 05-18-2014 06:18 AM
Last Post: chenfon
  plastic fuel tank bakonick 12 12,572 12-26-2012 12:08 AM
Last Post: bakonick
  Replacing the gas tank amigaguy 12 23,422 07-29-2009 10:36 PM
Last Post: amigaguy
