Full restoration...
06-27-2014, 10:35 PM
Post: #41
Full restoration...
hi,
no, I have used a cnc milling machine and the material was aluminium... I make a picture next time... and yes, its a lex is 200 (300) greets Dom |
07-28-2014, 08:17 AM
Post: #42
Full restoration...
einige kleine updates...
die neugefertigten bremsleitungen verbaut (nach einigem hin und her wegen den haltern...) die leitungen sind rundherum, inkl. der leitung an der achse und dem kupplungszylinder endlich das dach vollständig eingebaut, nachdem ich ein teil davon neu fräsen musste die bremse hinten ist jetzt vollständig zusammengebaut, fehlen nur noch die scheiben und klötzer für vorne bis bald marco |
07-28-2014, 01:17 PM
Post: #43
Full restoration...
Zero kms car!!! wow))
My car even older than I. Dec. 1983 zenki Levin coupe AE85 swapped to 4age16v from ae92 and other needed stuff and RHD to LHD Nov. 1985 kouki Trueno hatchback AE85, with 86s suspension, @3A + A42DL, RHD |
07-29-2014, 10:24 AM
Post: #44
Full restoration...
rhd in german wow where did u get it ??
u have rhd in german ?? |
07-29-2014, 10:36 AM
Post: #45
Full restoration...
why you think that is an rhd car?
07-29-2014, 11:02 AM
Post: #46
Full restoration...
KoJl6ACA Offline
Junior Member ** Posts: 23 Joined: Jan 2014 Reputation: 0 RE: Full restoration... Zero kms car!!! wow)) My car even older than I. Dec. 1983 zenki Levin coupe AE85 swapped to 4age16v from ae92 and other needed stuff and RHD to LHD i am sorry didnt read well i am connfuse |
09-08-2014, 09:49 AM
Post: #47
Full restoration... | |||
09-08-2014, 10:08 AM
(This post was last modified: 09-08-2014 10:11 AM by KoJl6ACA.)
Post: #48
Full restoration...
=) You looks happy during all the video, congratulations!
But one little question, is it smoke or steam comes our from exhaust? because as far as i've seen from your thread engine was overhauled isn't it? My car even older than I. Dec. 1983 zenki Levin coupe AE85 swapped to 4age16v from ae92 and other needed stuff and RHD to LHD Nov. 1985 kouki Trueno hatchback AE85, with 86s suspension, @3A + A42DL, RHD |
09-08-2014, 10:27 AM
Post: #49
Full restoration...
the head must remove, I have a leak from the gasket... oil and water, but I would drive
11-19-2014, 09:30 AM
(This post was last modified: 11-19-2014 09:31 AM by Blade1988.)
Post: #50
Full restoration...
thats why he loosing oil...
[/URL] but the new head is ready to build up [/URL] [/url] [/URL] [/URL] [/URL] [/URL] [/URL] the engine is ready and runs |
Another danish restoration | Duze | 61 | 71,061 |
03-20-2016 08:58 AM Last Post: Duze |
'84 ae86 restoration project | HybriD07 | 19 | 24,594 |
10-13-2014 09:20 PM Last Post: HybriD07 |
TOYOTA COROLLA Ke70 - Restoration project | cke70 | 34 | 50,266 |
07-02-2014 10:12 PM Last Post: cke70 |
Black Limited restoration | slpery86 | 6 | 9,803 |
12-17-2013 09:22 PM Last Post: banpei |
A.D.D Performance AE86 RESTORATION NEARLY COMPLETE | cab32 | 24 | 29,574 |
08-08-2013 09:27 AM Last Post: Martynas |
