GZE wiring fault
11-14-2008, 03:47 PM
GZE wiring fault
Hi guys,
my issue is with the black 2 pin connector next to the battery. This provides +12v on both pins when ignition on, and 0v when ignition off One pin provides power to the ECU, unsure on what the other one is for. I have wired up my injectors to this line. So they turn on at the right time. My problem is when I turn ignition off, the engine still runs, even though I have measured this plug at 0v When I disconnect the connector, the engine stops running. If I disconnect the battery in this state the engine carries on running! I believe this is because the alternator provides power to the power line still, but I don't see how it has a full circuit connection to the negative side of the battery when I disconnect that. So what have I done wrong? ![]() |
11-15-2008, 06:48 PM
GZE wiring fault
Never mind chaps, I sorted it now
Tail light wiring... | Mylesmck | 4 | 1,327 |
02-02-2024 12:36 PM Last Post: Mylesmck |
Lambda sensor wiring | sam3007 | 10 | 4,952 |
4A-GE wiring engine to chassis connectors | Lykowsky | 4 | 7,335 |
06-20-2019 11:38 AM Last Post: Lykowsky |
Some wiring help needed | DJexor | 5 | 5,754 |
AE86 Headlight + wiper wiring (levin) | bozu | 11 | 16,777 |
09-19-2017 02:06 PM Last Post: banpei |
