GZE wiring fault
11-14-2008, 03:47 PM
GZE wiring fault
Hi guys,
my issue is with the black 2 pin connector next to the battery.
This provides +12v on both pins when ignition on, and 0v when ignition off
One pin provides power to the ECU, unsure on what the other one is for.
I have wired up my injectors to this line. So they turn on at the right time.
My problem is when I turn ignition off, the engine still runs, even though I have measured this plug at 0v
When I disconnect the connector, the engine stops running.
If I disconnect the battery in this state the engine carries on running! I believe this is because the alternator provides power to the power line still, but I don't see how it has a full circuit connection to the negative side of the battery when I disconnect that.
So what have I done wrong? Confused
11-15-2008, 06:48 PM
GZE wiring fault
Never mind chaps, I sorted it now Thumbs up!
  Tail light wiring... Mylesmck 4 1,337 02-02-2024 12:36 PM
Last Post: Mylesmck
  Lambda sensor wiring sam3007 10 4,967 05-23-2022 10:00 PM
Last Post: The Doctor
  4A-GE wiring engine to chassis connectors Lykowsky 4 7,354 06-20-2019 11:38 AM
Last Post: Lykowsky
  Some wiring help needed DJexor 5 5,757 05-18-2019 01:50 PM
Last Post: DJexor
  AE86 Headlight + wiper wiring (levin) bozu 11 16,802 09-19-2017 02:06 PM
