Group a homologation questions
06-02-2015, 11:19 AM
(This post was last modified: 06-02-2015 11:40 AM by d3nso.)
nvm my old post it was crap...
Yea E1 could be an option Daily Beater: Civic EG5 Work in progress Car: AE86 |
06-02-2015, 11:35 AM
Grp a until 1300cc? Xd
06-02-2015, 02:31 PM
(This post was last modified: 06-02-2015 03:25 PM by Uzelac.)
(05-17-2015 05:22 PM)ditn Wrote: thanks for info If it isn't specified, than it is free to modify. Always have been. Performance in Gr.A come from CR, cams, porting and gearbox. I bet SCCR box is allowed. |
06-02-2015, 02:49 PM
Well not according to the inspector that came.
He said everything must be done according to book and everything Not mentioned is original |
06-02-2015, 03:26 PM
(This post was last modified: 06-02-2015 03:26 PM by Uzelac.)
Is that FIA sanctioned event or something else ?
06-02-2015, 04:20 PM
Fia sanctioned event national rallyevent
06-02-2015, 04:45 PM
(This post was last modified: 06-02-2015 04:45 PM by oldeskewltoy.)
(06-02-2015 02:49 PM)ditn Wrote: Well not according to the inspector that came. (06-02-2015 04:20 PM)ditn Wrote: Fia sanctioned event national rallyevent I believe your inspector is full of dung. I'd check with the FIA directly... give them the name of the inspector and explain the situation. It shouldn't be your fault the inspector doesn't know the rules....... Dan - You can | .... OR you can ask for help!!! OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
06-02-2015, 05:27 PM
(06-02-2015 02:49 PM)ditn Wrote: Well not according to the inspector that came.Well use the TRD Bible as 'the book' I'd ask around this inspector sounds iffy... AE86 ex-daily |
06-02-2015, 07:33 PM
He is one of the inspectors of the racb that inspects car before
They are given a yellow book. More information is however always better |
06-02-2015, 10:31 PM
(This post was last modified: 06-02-2015 10:37 PM by Bean.)
(06-02-2015 07:33 PM)ditn Wrote: He is one of the inspectors of the racb that inspects car beforeYou just answered yourself, "he's ONE of" - ask another Most literature is open to a bit of interpretation. Also as was mentioned before he's comment sounds off. For example Swiss law mentions a lot of things you're not allowed to modify at least not without proper paperwork but dampers are not mentioned anywhere and one can do/fit whatever he wants as long as you change the damper only (no altering of the strut in McPherson case). AE86 ex-daily |
20v Silvertop - New Haltech ECU & Couple of questions | 20valver | 10 | 2,003 |
Windscreen stoopid(?) questions.... | Mylesmck | 7 | 914 |
Brake Bias Questions | mad.matt | 10 | 11,045 |
wider rear axle,track width,suspension questions | ditn | 6 | 8,560 |
Suspension questions | leon205gti | 17 | 14,450 |
