Wiring loom Question.
04-20-2006, 02:45 PM
Hi all
I wase thincking about the AE86's Wiring loom. They are prety rare and expencive. On an other hand we have the AE82 Wiring loom. This car is most popular than the Hachi and cheeper than the 86. If i'm not mistaken there are blue top on the first gen of the 82. So the question is: Can the AE82 Wiring loom (with blue top) can fit on our hachis? Are the bolt on ...? Do they need some modifications..? Thanck's for your help. Best regards BOOMEX :wink: SR Team BURN THE RUBER NOT YOUR SOUL! |
04-20-2006, 02:53 PM
Needs some modifications ....but everything is there, all the connectors are the same. The layout is a bit different. You'll need to lay it out with the insulation off and lenghten and move wires around. So it's possible, but not straightforward.
04-21-2006, 08:08 AM
Thancks Ivan141
I'm going to see if thre is any 82 in the "casse" that i know. (casse<=dont say it in englich) Can you have some pics or information about themodification to do at the Wiring loom ? :wink: SR Team BURN THE RUBER NOT YOUR SOUL! |
04-21-2006, 10:18 AM
I dont have pics, but I know how it compares to an ae86 wiring loom because I used one to fix a burned ae86 loom. We layed it across the engine and a lot of stuff matched up, but some things are in totally different places. I chose to butcher the ae82 loom because it would be easier to fix the ae86 loom than to modify the ae82 loom. It is not impossible to do it though.
Tail light wiring... | Mylesmck | 4 | 1,125 |
02-02-2024 12:36 PM Last Post: Mylesmck |
Lambda sensor wiring | sam3007 | 10 | 4,649 |
4A-GE wiring engine to chassis connectors | Lykowsky | 4 | 7,094 |
06-20-2019 11:38 AM Last Post: Lykowsky |
Some wiring help needed | DJexor | 5 | 5,596 |
AE86 Headlight + wiper wiring (levin) | bozu | 11 | 16,207 |
09-19-2017 02:06 PM Last Post: banpei |
