HELP PLS!
03-29-2007, 09:41 AM
HELP PLS!
sr5 also has drum brakes in the rear, and a different gear ratio.
you coould just swap in a 4age... but i would advise you swap in the gts rear end as well |
03-31-2007, 01:04 AM
HELP PLS!
i started as an SR5 and slowly swaped everything. the hardest part for me was the rear end i use a celica supra rearend more beefeir vs the GTS rearend.im also useing a 4agze motor from an ae101 1995 levin.
03-31-2007, 09:01 AM
HELP PLS!
4agze Wrote:i started as an SR5 and slowly swaped everything. the hardest part for me was the rear end i use a celica supra rearend more beefeir vs the GTS rearend.im also useing a 4agze motor from an ae101 1995 levin. You dont happen to know were i can get a celica rearend, and also get it shipped to Denmark?. I might take a few if the price is right. /Skassa Any fool can go fast in a straight line. VEMS Blacktop 4AGTE20V 272hp/350nm """www.turbotoys.dk""" |
04-07-2007, 05:01 PM
HELP PLS!
depending on how much power and what you're gonna use the car for, you can put a decent Weber 32-36 Progressive Carburetor inplace of the stock one. You can get a SR5 running pretty quick pretty fairly cheap. But 4ac internals are pretty skimpy compared to a 4ag. Depending on budget...
check out Paradiseracing.com |
04-17-2007, 02:06 AM
HELP PLS!
yeah i did check paradise racing 600buck huh! woah its almost buying a engiine...but with out the head ache
Help PLS!! | wormwam | 5 | 5,586 |
03-04-2008 11:46 AM Last Post: apardal |
Help needed pls before POS Hatchi is sent to the USSR. | Yonzie | 11 | 10,806 |
11-16-2005 11:53 PM Last Post: dAYTONA |
