HKS 260 8.0 Cam Card
02-05-2018, 11:29 PM
Hi there,
does anyone happen to have the cam card for HKS 260°/8.0mm lift camshafts? Regards Daily Beater: Civic EG5 Work in progress Car: AE86 |
02-06-2018, 05:32 PM
2202-RT093 Toyota - 4A-G(Z)E - Intake - 256 degree - 8mm lift
2202-RT094 Toyota - 4A-G(Z)E - Exhaust - 256 degree - 8mm lift 2202-RT095 Toyota - 4A-G(Z)E - Intake - 264 degree - 8.1mm lift 2202-RT096 Toyota - 4A-G(Z)E - Exhaust - 264 degree - 8.1mm lift 2202-RT097 Toyota - 4A-G(Z)E - Intake - 272 degree - 8.1mm lift 2202-RT098 Toyota - 4A-G(Z)E - Exhaust - 272 degree - 8.1mm lift (these are no longer available) 2202-RT030 Toyota - 4A-G(Z)E - Intake - 248 degree - 7.45mm lift 2202-RT031 Toyota - 4A-G(Z)E - Exhaust - 256 degree - 8.35mm lift 2202-RT032 Toyota - 4A-G(Z)E - Intake - 264 degree - 8.35mm lift 2202-RT033 Toyota - 4A-G(Z)E - Exhaust - 272 degree - 8.35mm lift 2202-RT034 Toyota - 4A-G(Z)E - Intake - 288 degree - 8.30mm lift 2202-RT035 Toyota - 4A-G(Z)E - 288 degree - 10.*mm lift 2202-RT036 Toyota - 4A-G(Z)E - Exhaust - 304 degree - 8.30mm lift These are all the HKS cams I know they made.... a 260 - 8.0 is not among them... could it be custom? Dan - You can | .... OR you can ask for help!!! OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
02-06-2018, 06:51 PM
Good question but did HKS offer custom services on camshafts?
02-14-2018, 12:02 PM
By the resonance here I asume nobody seen this type before? Any recomendations regarding setting them up?
02-14-2018, 06:25 PM
(02-14-2018 12:02 PM)d3nso Wrote: Any recomendations regarding setting them up?The same way as any 4AG cams. I mean the cam card is useful for knowing the specification, but it doesn't change anything else. install them in your engine, set the valve clearance to IN: 0.20mm / EX: 0.25mm (like 99% off cams on this engine) and that's it. If you have adjustable cam pulley you can set your intake to something between 5/10° BTDC @1mm (max lift ~106/108° ATDC) and your exhaust between 0/5° ATDC @1mm (max lift ~110° BTDC) to get a baseline. With this cam duration the exhaust timing should not have a huge impact on performances, on the other end the intake timing can have a significant impact in mid-range. |
02-14-2018, 08:29 PM
This thread has a number of HKS cam cards.....
http://www.aeu86.org/forum/Thread-Anyone...#pid171779 Dan - You can | .... OR you can ask for help!!! OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
HKS valve springs | totta Crolla | 3 | 2,118 |
HKS Legal exhaust | Nakilad | 2 | 4,629 |
07-31-2019 10:00 AM Last Post: Nakilad |
Cam Cap Bolt Snapped!! | Alex170984 | 1 | 3,669 |
06-08-2018 01:17 PM Last Post: Ivan141 |
Anyone farmiliar with hks camshaft types for 4age? | spill86 | 5 | 15,584 |
11-18-2017 11:36 PM Last Post: oldeskewltoy |
hks 272º | ae86canarias | 4 | 10,182 |
07-29-2013 05:56 PM Last Post: oldeskewltoy |
