Handbrake help needed.
10-14-2007, 06:51 PM
When I pull my handbrake (while driving) I can lock my right wheel but not my left.
I always thought that this was because my left brake wasn't good. But when I tested the brakes on a brake tester (remmenbank) I saw that when braking with the pedal , both rear side brake equally. But when braking with the handbrake the right side brakes a lot while the left does almost nothing. I checked under the car and all the cables moved freely. ![]() |
10-14-2007, 07:27 PM
Then probably the handbrake lever on the caliper is stuck?
![]() See here how to it works http://www.aeu86.org/viewtopic/ae86/p/67359#67359 Try to see if you can find out if the left lever is still moving. 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: ![]() |
10-14-2007, 08:11 PM
If you had rebuilt the rear calipers you could had assembled it wrong.
See what banpei said... The steel cable is in good condition ans is fitted in its place? Keeping the AE86 alive! |
10-15-2007, 01:38 AM
i have the same, but other way arround, only the left. And to put a tire mark on the ground, i really need to push the handbrake lever.
I rebuilded it to, but i dont give the handbrake other use than park, so i got a bit careless. But i'll check it for the next mot. ![]() Cump´s Filipe Oliveira |
10-15-2007, 12:32 PM
I didn't rebuild the calipers.
I did check the lever and they both moved freely...so I don't know. I'll try to jack the rear wheels up, spin them and then try to pull the lever by hand and see what happens. |
10-15-2007, 02:27 PM
What's the condition of the brake pads and discs?
10-15-2007, 10:36 PM
brake pads are almost new. Disks are old, but plenty of thickness left.
10-16-2007, 08:05 AM
Shouldn't be the pads and disks if they work fine on the foot brake...
Maybe just put some fresh handbrake cables on? Thats a worthwhile replacement after 25 years in all situations. Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi ![]() |
Handbrake adjustment discs? | DMC | 8 | 2,248 |
Help needed | totta Crolla | 3 | 4,114 |
05-15-2020 10:07 AM Last Post: totta Crolla |
Some wiring help needed | DJexor | 5 | 5,754 |
Help needed: is it 1 way or 1.5way LSD | Dino86 | 2 | 3,839 |
05-17-2019 09:08 AM Last Post: Ivan141 |
Hydraulic handbrake with stock rear brakes | Dino86 | 11 | 16,169 |
07-11-2014 08:33 PM Last Post: Dino86 |
