Heater Pipes Diagram
06-05-2007, 03:06 AM
Hey,
Can any one help out with a photo or diagram for the heater hoses. I am unsure which hoses goes to where from where....
I really don't want to create an airlock by connecting the hoses to the wrong outlets/inlets etc.
Cheers
06-05-2007, 05:15 PM
Have you got a factory AE86 bigport setup (pipes, outlets etc ) or have you made up something.
06-05-2007, 07:59 PM
Is this that you are looking for?
[Image: AEU86 AE86 - Heater Pipes Diagram]
Keeping the AE86 alive!
06-05-2007, 09:35 PM
i could use that pic. thanx:-D
06-05-2007, 10:15 PM
Yeah I have a factory setup in regards to the water pipes/outlets.
Cheers for the pic Rasteirinho. Has saved me many problems!
Cheers
06-05-2007, 10:17 PM (This post was last modified: 04-27-2014 04:57 PM by Sanity Clause.)
Here's another, with more detail.
While you've got the pipes off, note that the thin "L" shaped pipe "16278" (top right) can get blocked with gunge, so give it a
good clean out.
If it does become blocked, it will stop the flow of hot water to the thermostat in the Auxilliary Air Valve. This can result in an
oscillation in the revs at idle speed.
http://www.AE86imports.0catch.com
06-05-2007, 10:24 PM
Cheers for the that Sanity Clause. Will check pipe for gunge.
Sweet Ta
  AE86 Heater Control Light Super86 8 9,337 07-20-2016 07:22 AM
Last Post: Super86
  HELP! need AE85 lisse/lime cluster diagram AE86_DRIFTER_ 0 3,526 06-27-2016 11:38 PM
Last Post: AE86_DRIFTER_
  Carina TA62 / TA60 heater blower stopped working Bushido 9 11,351 11-14-2014 12:57 AM
Last Post: Bushido
  Heater issue Jezza_hr 9 13,260 10-02-2014 07:51 PM
Last Post: Jezza_hr
  Digital Cluster Pinout Diagram. assassin10000 4 12,245 02-20-2013 04:46 PM
Last Post: choyr
