Hello European AE86 family
09-16-2004, 09:02 PM
Yooooo Will
.. Welcome
09-16-2004, 09:19 PM
Hey Kristian.
So when are you coming over for some UK drifty fun?
09-16-2004, 09:20 PM
Hey Kristian.
09-16-2004, 10:35 PM
banpei Wrote:
NoHachi Wrote:I'd hardly call the AE86 an underdog. Word has gotten out enough for people to recognize one when they see one. Then YOU have to step up to the expectations generated by all those great drivers in the Japanese driftmovies. Good luck on that one :!:
You are absolutely right on that one. Wink
Well yes and no. Sure loads of people who are into cars know the 86, but in Holland it still is a fairly unknown car. It wont be for long through as drifting is also here gaining more popularity.
You will know when that time has come when a rusty old coupe costs you 4000 euroSmile
09-16-2004, 11:28 PM
20vWill Wrote:Hey Kristian.
Well..this year seems to be to forget..... about it really.
I blew my racing clutch this weekend....
But i did win the cometition though.
K
09-16-2004, 11:39 PM
Congrats on the comp win.
Bad luck on the clutch.
What's stopping you getting another one? Helix can do you a nice cerrametallic 4-puck comp clutch...
09-17-2004, 12:24 AM
20vWill Wrote:Congrats on the comp win.
What would this cost possibly ?
Confused:
09-17-2004, 02:43 AM
Well, depends what's up with yours...
If you've just burned out all the friction material, you could send it off to the manufacturer to get the plate re-lined for pretty cheap (~£50 over here I think).
If you need a completely new kit:
Helix organic or cerrametallic clutch kits run around £300 + VAT complete with stiffer cover, plate and release bearing.
I've got a 4-puck Helix cerrametallic (212mm flywheel) kit, that was £325 + VAT. It bites like a bitch-whore from hell and doesn't know the meaning of slip. Still going fine after about 18 months drifting (though not too much abuse).
Standard blue-top flywheels are 200mm and so suitable clutches are slightly cheaper. Worth putting a late small port red-top flywheel in as it'a a bit lighter and more friction surface (212mm) or even better one from an AE111.
Try http://www.helix-autosport.com
Hope this helps.
09-17-2004, 03:54 AM
Hey Will, I love the look´s of your Hachi. Those supra rims look cool every day of the week on a Hachi. Thank god I have a set myself back home in the shed Smile
Anyways.....whats the deal with that scoop looking thing below the engine?
09-17-2004, 04:49 AM
Peter,
Yeah MA61 wheels are OK for cheap, but a serious AE86 deserves something a bit deeper... I've got some 15x8 split rims I got for cheap that should suit the AE86. I'll have to work out the offset when I get them to hand, and the holes will need re-drilling for 114.3 PCD. The rim bolts also need replacing, the centres need painting and the lips need polishing...
Errr the scoop thing is a piece of random ducting hose found in a skip. It hangs under my front ARB and snakes up to the throttles to supply them with a little cooler air. Probably doesn't do too much, but certainly doesn't do any harm. Seems to freak a lot of people out that one...
  Hello hello from Brunei!!! :cheer: berryred 2 4,703 04-28-2011 09:36 PM
  hello hello! Chapstick 5 6,280 05-31-2010 10:09 PM
  New Supra in the family surfingdrums 16 13,567 08-28-2006 10:39 PM
Last Post: surfingdrums
