:: Hello newb to the board and Pics of my 86 ::
09-14-2009, 12:14 AM
Thanks for the input ivan!
moutns not worried about so much as for the wirring i have a few locla toyota guru's that can help i'm an electrical failboat!
Before askign redundent questions i went off for siad build thread you suggested.
However can;t find it under the search or even the users homepage?
direct link?
cheers!
[Image: AEU86 AE86 - :: Hello newb to the board ...f my 86 ::]
09-14-2009, 12:44 AM
if your heading down either the silver or blacktop route, check this guy out.
will sort all your cooling needs, and has a few other very nice toys to make the conversion go really easy.
http://s-86.com/
frieght isnt too bad from our end... he is in aus Smile so dont be too shy to shoot him a email or something. Smile
blacktop is a very nice engine, but the internal knock sensor in the ecu is VERY sensitive, so tends to retard very early in the peice. Silvertop bottom end is a bit stronger if you plan on going boost at any stage Smile
good luck Smile
clutch kick, switch, tree .... oowwww
09-14-2009, 02:46 AM
Hey thanks for the links!
i will go check them out now,
I'm not a Forced induction kinda guy i much preffer N/A all the way.
so any more pros or cons of either motor would be helpful.
I will be reading and absorbing as much info over the next month or so before i decide anyway as the car is in storage for the winter anyway. Some other areas as well as motor will be addressed over winter.
and Ivan i foudn the thread and read it thanks for the dicrection very helpful!
so far this board is great as a new 86 owners guide. glad i chose it over others!
09-14-2009, 04:24 AM
blacktop head is nicer and the rods are great for standadr, but are prone to stretch at really high revs.
to get the most out of it, a complete ecu swap would be best Smile
or beams.... Huh
09-14-2009, 05:02 AM
both of those motors come with ecu's
when you say high revs the rods stretch how hight we talking??
i'm known to bring my cars right up failry often
09-14-2009, 05:27 AM
9000 plus. you wont do it on a standard ecu
if you have the choice and must use the standard ecu then the blacktop is worth the map sensor alone Smile
means open trumpets Smile
09-14-2009, 10:14 AM
You re all set up well Pete, marriage sorted out, car sorted out, wheels sorted out, forum sorted out. What else can a man asl for? Smile
[Image: AEU86 AE86 - :: Hello newb to the board ...f my 86 ::] http://www.jdmbits.com
09-15-2009, 06:19 AM
a wallet that doesn't go empty so quick hahahahahahah
  Hello hello from Brunei!!! :cheer: berryred 2 4,479 04-28-2011 09:36 PM
  hello hello! Chapstick 5 6,028 05-31-2010 10:09 PM
  new here and hello from Germany SAM 7 8,805 01-03-2010 12:52 AM
Last Post: leckter
  Newb from San Diego, CA USA saying hello!!! (LOTS OF PICS) ryceboy_124 3 4,710 07-03-2009 10:46 AM
Last Post: ryceboy_124
  Sayin hello (finally got the pics up) lv_AE86 7 5,891 03-16-2009 01:18 AM
Last Post: lv_AE86
