Help with Kouki Trueno bumper cover install!!!
11-16-2007, 04:12 AM
I am in need of some help with the installation of a kouki trueno bumper cover on my 1985 sr5 corolla usdm. I have the brackets on order to install. I know I need them, but I can't seem to place how to mount the bumper correctly. Do I need to remove the factory steel bumper? If you could point me in the right direction I would be very grateful. I also tried to fit the bumper and and it would not fit around the factory sr5 bumper because the actual bumper is too thick in reference to the area to bolt up the trueno bumper cover. Any help would be much appreciated. Maybe a write up or link!?
I can add photos if someone is better visually looking at the problem. |
11-16-2007, 04:52 AM
//wannabe mod mode:
I'm no bumper expert, but i'm fairly good with computers. PrOpEr use of capslock or shift can make your posts look a bit more friendly and modest // foto's would be handy ![]() He attacked everything in life with a mix of extrordinary genius and naive incompetence, and it was often difficult to tell which was which. |
11-16-2007, 07:26 AM
You need to remove the complete USDM bumper... at the frame. The new brackets will have 4 pick up points. Once the brakets are on... and you slip on the cover, I'm sure mounting points will be revealed.
Are you also getting kouki turn/parking and cornering lamps??? If you have USDM bumper and you want to wire in the lights to operate correctly... then you need to do a bit of wiring ![]() ![]() Dan - You can | ![]() OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
11-16-2007, 10:42 AM
senna Wrote://wannabe mod mode:Thanks ![]() Just corrected the title. ![]() 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: ![]() |
Bash bar for zenki trueno bumper | gh0st | 3 | 2,020 |
02-08-2023 10:50 PM Last Post: Ivan141 |
Can you seperate trueno kouki bumper lights into zenki bumper lights? | gh0st | 17 | 10,009 |
12-19-2021 11:58 PM Last Post: gh0st |
Trueno headlight help | kazi | 9 | 13,715 |
04-20-2017 09:37 AM Last Post: kazi |
JDM trueno not starting. need help! | kazi | 8 | 9,601 |
CD player install. | kazi | 8 | 9,840 |
02-21-2017 11:57 AM Last Post: banpei |
