High-beam warning lamp
07-20-2023, 05:06 PM
Hello everybody,
I'm experiencing some issues with my headlights; on full beam the blue warning lamp is really dim, barely detectable by the human eye. Has anyone experience of this? The earth is good, the other warning lights (door open, fuel) are much brighter. When it's lit, it's only getting 6volts which appears to be correct to as per the wiring diagram, ie. I series with the low beam so 6v + 6v = 12v. Should it be a different rated bulb? 6v as opposed to 12? Any guidance appreciated |
07-20-2023, 08:13 PM
Don't worry, all sorted now
07-20-2023, 11:22 PM
What was the cause then?
07-21-2023, 12:35 AM
I had mixed up the terminals at one of the headlights, effectively putting the main and dip filaments in series and taking 6v from between them to feed the warning light
07-21-2023, 07:44 AM
(07-21-2023 12:35 AM)Mylesmck Wrote: I had mixed up the terminals at one of the headlights, effectively putting the main and dip filaments in series and taking 6v from between them to feed the warning lightThanks! That explains it indeed. 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: |
Engine stress at high speeds | gh0st | 6 | 2,458 |
08-30-2022 07:11 PM Last Post: Power_uP |
4AGE 16V engine overheat when at high speed | chenfon | 32 | 21,329 |
Bonnet lamp pod for AE86 | Dino86 | 0 | 2,942 |
01-04-2018 11:08 PM Last Post: Dino86 |
Early EDM non-cat 4A-GE 16v Bluetop Fails emissions (high co) | Rascal21 | 41 | 33,572 |
08-21-2016 04:51 PM Last Post: ray |
Peculiar headlight issue - main beam | Jezza_hr | 3 | 5,719 |
10-04-2015 09:25 PM Last Post: Jezza_hr |
