Hooking up light buzzer
10-17-2005, 10:20 AM
Hey Guys,
Okay I'm getting a bit fed up with this, I keep leaving my lights on and being left with a drained battery. Time to install one of those annoying buzzers that lets you know you left your light on when you turn the ignition off.... Call me stupid but since I've never installed one of these things, whats the best (and easiest) way to hook one of these up in a hachiroku? Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi |
10-17-2005, 10:36 AM
Hmmm, I still have my door-buzzer. Dunno if you can use that one, but here you can see where it should be situated:
http://www.aeu86.org/viewtopic.php?t=1584 I couldn't find find it in the wire-diagrams, but I think you can do a slight modification and make a light-buzzer out of it. 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: |
10-17-2005, 10:57 AM
Banpei, do you mean the 100kph buzzer? Doorbuzzer is same as light buzzer, just buzzes when you have lights on and open door. Basically the thing I need.
I'm just gonne pick up a unit at halfords in a minute Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi |
10-17-2005, 11:04 AM
Guys i am interested in connecting one in my car too...
Please give me instuctions to do so if you 'll finally manage to do that connection. AE86 FANATIC!!! |
mux213 Wrote:Banpei, do you mean the 100kph buzzer? Doorbuzzer is same as light buzzer, just buzzes when you have lights on and open door. Basically the thing I need.Ah, then I have the right buzzer for you. It is indeed the door/light-buzzer that used to be in my car. It is of no use for me, if I leave my lights on and don't see it I must be blind. 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: |
10-17-2005, 12:01 PM
I put one in my moms car once, it came with instructions. You either have to wire it into the door-switch, which is a bit fiddly, or you can wire it to go off when the ignition is off and the lights are off. To do this you can usually just poke some wires in between 2 fuses in the fusebox. (ignition and lighting fuses). It's basically just a buzzer with a diode in series. When the ignition is on and the lights are off it gets 12V from the ignition and 0V from the lighting fuse...the diode blocks the current in this direction...when both fuses are powered (ignition & lights on) there is no difference in voltage and no current will flow. When the lights are on and the ignition is off current will start flowing in the right direction and voila...it will buzz. All you have to figure out is which way the wires should go.
10-19-2005, 10:42 AM
mux213 Wrote:Hey Guys, You're not the only one Mux Lucky me still had no drained battery. 5/2018 BMW F22 Coupe 1/1985 Toyota AE86 Levin Coupe |
Disabling the speed warning buzzer on a JDM Levin | Ian.G | 22 | 31,955 |
06-09-2008 05:31 PM Last Post: cavey |
