Hot IdleProblems
02-04-2006, 01:12 AM
Hot IdleProblems
Here's my recentley purchased '86 ae86 4age levin
My problem is hot idle . when the engine is cold it revs fine at idle ( occasionly 2300 rpm , but pick the throttle and that settles out. ) when the engine reaches 45% on the scale and the engine is under no load ( neutral , no rear heated window ) the engine revs up and down between 700 and 1800 rpm this makes crawling in traffic difficult and sounds terrible too. ( grief from the missus ) if a load is put on the engine , half clutch or sometimes lights , heater & fans on, the idleing settles for a few mins. i've checked coolant level , this was low but filled and no change. btw a sports air filter is fitted. i was told this could affect it. the valve cap in the throttle body was repalced with a tyre cap that didn't make any diff either. a friend mentioned it could be a leaky vaccuum pipe somewhere. where and what should i check next ? i'm still kinda green ya see. |
02-04-2006, 04:03 PM
Hot IdleProblems
any takers ?
02-04-2006, 06:28 PM
Hot IdleProblems
It sounds like the problem Oldskull also suffers from:
http://www.aeu86.org/viewtopic.php?t=2500 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: |
02-04-2006, 06:50 PM
Hot IdleProblems
TPS sensor is faulty.
Jón Mar "T3 is good. I'd go with them. And they're red. Red goes faster..." '87 AE86 3dr - Black '87 AE86 3dr - Red '88 AE92 5dr GTi - Black '95 ST205 - Red - sold |
03-05-2006, 10:11 PM
Hot IdleProblems
I had this problem on my MG Midget (4AGE installed). It was fine when engine cold, but when it warmed up it would hunt all over the place. I narrowed it down to the IAC valve under the throttle intake. I took it off and replaced it with a flat sheet of Aluminium, and just linked the two water pipes together, car now needs a few pumps of the throttle to get started and then takes a 30 secs before it will idle, but after that, not a problem.
Ivan 1972 MG Midget - AE86 Engine, Ford Anglia Axle - Escort LSD - Live the Dream!!1 |
03-06-2006, 03:00 AM
Hot IdleProblems
you can screw up your idle to 1k rpm which is fine. The screw is next to your intake!
04-02-2006, 10:04 AM
Hot IdleProblems
When my ae85 idles it is at about 500 - 550 rpm, this is far too low. sometimes when i am just sitting at the lights the car stalls itself which is very embarrasing (either people think i am a crappy driver or they know i have a bad car http://www.aeu86.org/viewtopic.php?p=41074#41074)
I figure that screwing up the idle should fix this but i dont know how, i dont have a 4 series engine either, it is a 3au. Can someone help me? i need to know what i am looking for and where it is to increase idle speed. Current Cars: '86 SE82 FX GT '88 NZ New KE70 Van (Daily) |
04-02-2006, 11:42 AM
Hot IdleProblems
I think carbs have some sort of idle air screw too. There are a few guys that know their way around those carbs here. You could try sending Ben a PM, his username is 1974KE25 around here, he usually knows his way around about every toyota there is.
Engine cranks slowly when hot... but starts | Dino86 | 9 | 13,578 |
02-03-2014 08:04 PM Last Post: Dino86 |
Hot oil filter - a problem? | harkes | 5 | 6,424 |
01-03-2014 09:33 PM Last Post: Apsogos |
Hot Wheels | Blue86 | 2 | 3,833 |
11-02-2010 02:19 AM Last Post: JonnyAE86 |
Wires getting hot! | choco | 8 | 7,184 |
11-23-2007 12:57 AM Last Post: choco |
