How to adjust camber on the front using standard adjustment?
06-17-2011, 12:57 PM
Just swap the left and right spring and you should be ok. With your weight added to the right side of the car it should be more or less even. (this is assuming that left is the drivers side of the car).
Can you also measure the ride height, from the front pinchweld to the ground. Should be that the right spring has sagged a bit more then the left.
Another option is that your right LCA a bit tweaked and it is now shorter then the right.
06-17-2011, 01:20 PM
Sorry, what is LCA? sometimes do not understand some abbreviations in english
[Image: AEU86 AE86 - How to adjust camber on the...djustment?]
06-17-2011, 01:31 PM
[Image: AEU86 AE86 - How to adjust camber on the...djustment?][/url]
1979 Toyota Corolla KE35
1983 Toyota Corolla AE86
1985 Toyota Corolla AE86
06-17-2011, 03:42 PM
All right, thanks, Lower Control Arm, i'll raise the car and look this, i've other set of LCA :wink: and 'll looking for any mistakes
06-17-2011, 04:55 PM
You can solve that with camber plates... But check if you have something wrong before. Anyway, from what I noticed, these cars tend to be a bit lower on the driver side, and that increases the camber (negatively). I solved that (height issue) cutting a bit on the back spring form the opposite side...
  Handbrake adjustment discs? DMC 8 1,670 03-10-2024 08:08 PM
Last Post: DMC
  What suspension set up are people using? kazi 8 8,040 07-06-2017 05:26 AM
Last Post: headrush
  What is normal and low caster in Cusco camber plates?? T_AE86 9 15,000 01-07-2016 02:56 AM
Last Post: Deuce Cam
  Camber adjustment vs original struts Lt86 9 9,278 05-07-2015 09:45 PM
Last Post: zenki
  Using a different diff in an AE86 megabob 6 8,199 02-17-2015 03:37 PM
Last Post: megabob
