How to remove my bumpers
10-30-2005, 02:39 AM
Ok this is a stupid arse question but I'm gona ask it anyways.
![]() Could some one tell me how to remove the front and rear bumpers. I had most of the bolts out for the front bumper but it still wouldnt come lose. Cheers I once read that you shouldnt believe everything you read. |
10-30-2005, 05:45 AM
think you can get the rear bumper loose by four screws that you access through the trunk floor. Plastic caps in the floor. Then the screws that attach it to the fenders.
The front should be by the fenders and then two more at the front. Or at least this is as much as i remember, long time since i did this, and that was in a hurry. Jón Mar "T3 is good. I'd go with them. And they're red. Red goes faster..." '87 AE86 3dr - Black '87 AE86 3dr - Red '88 AE92 5dr GTi - Black '95 ST205 - Red - sold |
10-30-2005, 08:15 AM
Oh cool...I'll try and have a look tomorrow. Cheers.
10-30-2005, 08:52 AM
Jon, there are 2 more screws for the rear bumper
![]() James this is what I remember: Rear bumper: - the 4 big ones in the floor plan - 2 small ones where the bumper meets the wheel arches - 2 small ones in the middle of the sides, also accessable from the trunk Front bumper: - 2 small ones where the front bumper meets the wheel arches - you can either unscrew the 8 screws mounting the bumper to the metal brackets holding it in place - or you can unscrew the brackets themselves from the shell, not sure how many screws those are ![]() Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi ![]() |
10-30-2005, 10:47 AM
mux213 Wrote:Jon, there are 2 more screws for the rear bumper Ahh thats what I wanted to hear....nice one Mux! I once read that you shouldnt believe everything you read. |
10-30-2005, 02:38 PM
If you can reach them try unhooking the front bumper where the main brackets go through the chassis. It's only 1 or 2 bolts per side, very big ones, and they tend to be difficult to get loose.There are also 2 small metal support brackets inside the wheelwell holding the bottom in place if I'm not mistaken..
10-30-2005, 05:27 PM
Or you can try using a fencepost, removed my front bumper in no time at all !
10-30-2005, 05:38 PM
Ivan141 Wrote:There are also 2 small metal support brackets inside the wheelwell holding the bottom in place if I'm not mistaken..Ah I forgot about those to.. they broke off on mine ![]() Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi ![]() |
10-30-2005, 05:39 PM
JonT Wrote:Or you can try using a fencepost, removed my front bumper in no time at all !It's putting it back on later on in the project thats the real problem there brother Jon ![]() Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi ![]() |
Remove paint from rocker covers | xrgeorg | 4 | 6,056 |
08-19-2011 03:05 AM Last Post: Lewy |
remove / replace starter | Dino86 | 10 | 17,919 |
05-27-2011 02:30 AM Last Post: allencr |
How to remove windows? | Eric | 4 | 4,819 |
03-10-2009 09:57 PM Last Post: Eric |
show me your front bumpers!! and identify mine | koh | 7 | 6,735 |
04-08-2008 01:48 AM Last Post: koh |
What's The Best Way To Remove Carbon Deposits? | Rasteirinho | 8 | 7,461 |
04-07-2007 04:51 PM Last Post: aeaw |
