How to save a cover rubber of gearbox shift ???
02-26-2011, 11:15 AM
Hi, i searched in the forum but i didn't find it.
I put on a T3 quick shift, and all was Ok, but the problem is that Toyota hasn't for sale the cover rubber of gearbox shift (not the boot), And i can't find a way to remove the rubber of the original shift, because below has the "rolling ball" with biggest lever balls and above a thick tube Banging head
Anyone know how to extract it?
This is the rubber:
[Image: AEU86 AE86 - How to save a cover rubber ... shift ???]
Rolling ball below:
Thick tube above:
Thanks. Regards
02-26-2011, 02:08 PM
You can only try to pull it over the "thick tube above" using dishwasher liquid, there is a 50% chance it breaks cause of age Tongue
But its not that bad if it breaks, the smaller boot beneath it is much more important, cause it keeps moist and dirt away from entering the gearbox!
The´re impossible to get of and always break.
I suggest this:
http://cgi.ebay.de/ws/eBayISAPI.dll?View...0631726166
It fit´s Toyota K50/K40 boxes and should fit T50, too (same dimensions). If you find something cheaper let me (us) know! :wink:
1979 Toyota Corolla KE35
1983 Toyota Corolla AE86
1985 Toyota Corolla AE86
02-26-2011, 06:04 PM
if you dont care about your original shifter, heat the thick tube, it's only glued
02-26-2011, 11:00 PM
fax0815 Wrote:The´re impossible to get of and always break.
I suggest this:
It's not bad idea, it protects the rollin ball, but i'm looking for something to separate the interior pieces of the under outside, like you said, is so easy to break the rubber. So the boot is still available, part reference: 33555-12090
Boot on the T3 (i assured with a band flange)
Project D, i'll try it, i think i'll not reassemble the original
Thanks
02-26-2011, 11:03 PM
you can use one form a nissan 200sx s13 or s14, they are a little bit larger but still available and will do the trick.
02-26-2011, 11:07 PM
eBay...
http://cgi.ebay.com/TOYOTA-COROLLA-KE70-...483f12db8e
http://cgi.ebay.com/ebaymotors/1989-95-t...ccessories
http://cgi.ebay.com/ebaymotors/COROLLA-K...ccessories
http://cgi.ebay.com/ebaymotors/TOYOTA-CO...ccessories
http://cgi.ebay.com/ebaymotors/TOYOTA-TE...ccessories
"Tämmösellä modernilla autolla, niin mun mielestä, ei tämmöstä kisaa voi ajaa. Tää käy kunnon päälle eikä riitä aivot tähän touhuun!"
""With a modern car like this, in my opinion, a competition like this can't be driven. It's too physical and your brains can't cope with this stuff"
-Henri Toivonen 2.5.1986-
http://www.youtube.com/watch?v=OwgB4Xs4LVQ
02-26-2011, 11:46 PM
I suggest this:
Thanks
Ok, but how much did it cost you from Toyota?
02-27-2011, 12:52 AM
Thanks, if i can't save it, that's the only solution
fax0815 Wrote:Ok, but how much did it cost you from Toyota?
It cost 8.41€
  car cover kawo 3 4,832 07-24-2013 09:09 AM
Last Post: totta Crolla
  Broken 20v upper timing belt cover chip 2 4,403 07-16-2012 07:11 AM
Last Post: Jan Pedersen
  Interesting 20v cam cover mod banpei 3 9,139 05-31-2012 02:44 PM
Last Post: Kid Karola
  Rubber sealing on oem sideskirts Jimmi The Kid 4 6,740 06-22-2011 09:16 PM
Last Post: Jimmi The Kid
  Front wheel bearing cover : Partnumber danworth 5 6,166 11-14-2009 01:09 PM
Last Post: danworth
