How would/have you rebuild your 4age?
12-09-2006, 10:51 PM
Ok, here´s the idea... I ve been for a long time thinking how should i rebuild my engine but there s so many different ways to get to the same result that im confused about the right one. That being the one that fulfills the objective you previously chose to your engine and most important... economic.
So whoever wants to can leave the link to their rebuild here or just state how would you rebuild your engine according to your target (ex. 160cvs with stock ECU, 200cvs, etc). Please, for those who have done it, state the price of the pieces you bought and where to help all of us (who are going for a rebuid) find the best prices and quality material. Thanks 85 Red Toyota Corolla GT - project "vouàfalencia" |
12-10-2006, 12:18 AM
i recomends pistons rings from CTI - very good quality
http://www.coreygarage.prv.pl |
07-20-2015, 02:54 AM
Know this is a old post...
I am thinking to buy this CTI piston rings to fit my 20v pistons. Anyone else have any opinion on these ones? regards |
07-20-2015, 07:29 AM
I've always used NPR japan pistons which you can get on ebay. 20V has top ring: 1,2mm middle: 1,5mm oil: 2,8mm but this kind of set is not sold (or I haven't found yet) on ebay, so I used to buy 7afe rings, which is the same set, but with 3mm oil rings and then you can use your old expander from the oil rings, which not used to worn.
like this: http://www.ebay.com/itm/400561823415 |
07-20-2015, 05:10 PM
Look up 1988-91 Honda Prelude rings...
They are 1.2, 1.5, and 2.8 available in standard size 81mm, and oversize 81.5mm Dan - You can | .... OR you can ask for help!!! OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
07-20-2015, 06:47 PM
awesome info......
07-21-2015, 10:40 AM
My 20v Rebuild list WAS (til I looked into the Cost vs. Reliability of attached components)
Bottom End: ACL Race Bearings Polished and Balanced OEM Crank BC Pistons and Carrilo Rods (might be the other way around) All ARC Bolts Battle Version Ladder Brace Block Skimmed TRD 0.8 Gasket OEM Oil and Water Pump Top End: Supertech Valve Guides Supertech Seals OEM Valves Tomei Poncams all other usual rebuild hardware But then the right package came up at a similar price so I decided against it. |
Can you convert your 86 back too the original state? | gh0st | 7 | 2,698 |
Bluetop Engine Rebuild multiple question Goal 150-160hp | Hanzo | 16 | 9,029 |
Rear Differential rebuild | chenfon | 10 | 9,040 |
11-20-2020 12:18 AM Last Post: totta Crolla |
AE86 4A-GE 16v engine harness rebuild | FanIsHere | 7 | 9,908 |
01-17-2020 08:04 PM Last Post: Project D |
Build your own adjustable fuel pressure regulator ;) | oldeskewltoy | 8 | 20,827 |
