I'm searching for this wheel
03-27-2009, 05:28 AM
hey guys.
there's a engine oil leak from the front of my engine and my mechanics are having a hard time removing this particular wheel. What do you call it exactly and is it there for purchase? by the way the pic is from rallyman1978 ![]() Cheated on my いたずらな女の子 and now I can't get enough of her.. |
03-27-2009, 05:53 AM
crankshaft timing pulley.
your supposed to use SST 09213-70010 and 09330-00020 to remove it. Basically a tool that bolts to the pulley so you can hold it while the other undos the nut. Then SST 09213-31021 to remove the pulley, which is basically a puller. You must be able to buy these new although I dont know the part number. It should be stamped on it . Might be this Pulley, Crankshaft Belt Drive 13521-16010 Here is the link to the 4ag manual. http://files.aeu86.org/manuals/4A-GEManual.pdf |
03-27-2009, 08:27 PM
03-28-2009, 01:14 AM
I usually drill 2 or more holes on them and smash 'em off with a hammer...and then buy new ones...
AE86 GT - SR20DET BlackTop //// Trackday beater Citroen C4 Coupe VTR - 1.6HDi //// Streetcar |
03-28-2009, 05:04 AM
thanks Hachi and Totta..
well if its cheaper to buy the wheel I might actually break it off.. Quote:I usually drill 2 or more holes on them and smash 'em off with a hammer...and then buy new ones... this is what my mechanic suggested but as I didn't know where to buy this wheel I told him not to. How much is this wheel and anyone has a link to this on ebay I couldn't find it? Cheated on my いたずらな女の子 and now I can't get enough of her.. |
03-28-2009, 11:41 AM
In my experience the timing gear is usually seized on after being on for all those years and usually breaks even when using a SST. In the end people seem to break either the gear or the woodruff key or both. You could try using a penetrator like PB Blaster to release the rust grip that's got the gear stuck on the crank, but even that might not work.
-Brandon |
03-28-2009, 09:28 PM
well I'm hoping that if its cheap to get the wheel to not care about keeping the wheel in one piece when removing. So anyone out there knows where I could get the wheel?
03-30-2009, 06:18 PM
I'd call up your local Toyota parts source.
-Brandon |
Searching for front springs (rally) | filh | 28 | 28,352 |
12-01-2007 10:55 AM Last Post: Jan Pedersen |
Searching and Help : good Exhaust !!!!! | MikeAE86 | 2 | 3,829 |
05-05-2005 04:51 PM Last Post: lsd addicted |
Shocks searching !!! Koni red for example !!! | MikeAE86 | 2 | 3,691 |
05-01-2005 11:41 PM Last Post: Aico |
