INjector Guide
12-16-2005, 07:37 AM
INjector Guide
Morten Wrote:That calculator is missing one important thing: max. rpmThis is actually incorrect. Power output and fuel consumption are closely linked, but the RPM has nothing to do with it. So if two cars have the same injectors and fuel pressure regulator and one produces 200hp at 5000rpm and the other produces 200hp at 9500rpm then their max injector duty cycle should be the same. Sure at high RPM, you have a smaller time to inject per stroke, but you have more strokes per second, so hence a greater number of injection pulses per second. Hen No, this thing is totally stock standard officer... |
12-26-2005, 01:36 AM
INjector Guide
Hen Wrote:This is actually incorrect. Power output and fuel consumption are closely linked, but the RPM has nothing to do with it. Good point! It seems I spoke before really thinking this completely through.. by bad ![]() However, in real life it would actually be something in between due to injector lag times taking a larger and larger percentage of the available time as the revs rise.. ![]() '85 AE86 4AGE, '94 SW20 3SGTE, '83 KP61, 72' RA21 |
Newb question on "how-to" guide for ITBs on JDM 4AG Bluetop w/ MAP | mister86 | 12 | 11,846 |
Injector voltage problem [fixed] | d3nso | 16 | 19,255 |
04-03-2016 12:39 PM Last Post: d3nso |
stock injector deadtime for 4age 20v silvertop/blacktop injector | ditn | 1 | 6,088 |
02-20-2016 11:48 AM Last Post: Bean |
Injector sizes info | ZaX | 19 | 37,096 |
07-17-2013 01:54 AM Last Post: jondee86 |
pink injector resistance | Apsogos | 2 | 4,198 |
10-01-2012 09:00 AM Last Post: Ivan141 |
