Impreza Group-N project.
01-14-2008, 10:05 PM
Post: #71
Doin great progress. Good looking.
How did you like the AST suspension?
I am jsut looking for a new one for mine.
Speed Industries
Hurdnerwaeldlistr. 73
8808 Pfaeffikon
Switzerland
e-mail: [email protected]
phone: +4155 420 15 69
page: http://www.speed-industries.ch
MSN: [email protected]
We have all the parts your Hachi needs
01-14-2008, 10:15 PM
Post: #72
Tobias, I sent you an email. Wink
01-18-2008, 10:25 PM
Post: #73
Teusday I fitted the gearbox subframe and the rear of the front wishbones.
I thought the thread was rusted so brought some tools to repair but it turned out that the threads were good enough to use after sitting outside for quite some time. Thumbs up!
I also removed the rear diff and axels:
[Image: AEU86 AE86 - Impreza Group-N project.]
Yesterday we did alot more thankfully. Cool Thumbs up!
We changed the whole rear suspension. Big Grin
Remove from the donor:
First of 3 parts:
View on the front:
Second of 3 parts:
Last part already under the new chassis:
Parts 1 and 2 fitted:
Everything's on:
On crutches:
On it's feet!!:
Later that evening 2 friends dropped by, Bjorn and Tim.
Tim can weld plastic and my dashbord has quite some welding to be done to.
Working together:
Fitting and measuring:
More next time!
01-19-2008, 07:23 AM
Post: #74
nice. coming along really well. Thumbs up!
te72 wagon
ae86 levin coupe project
01-22-2008, 11:39 PM
Post: #75
Today I tried the dash loom in.
I had some doubts on wether it would fit or not, mainly the heater could give some problems.
GL very empty:
The big question, will the heater fit with the loom inside?
Well, part 1 is in:
Part 2 is in:
En waddayaknow, the blower fits also!!:
Now I'm going to look if I can cut some more wire from the loom, that will save some weight and make it a bit easier to fix. Big Grin
01-23-2008, 11:29 PM
Post: #76
n1 going. Hey aram aren't you gonne paint it first?
01-27-2008, 07:40 PM
Post: #77
No m8, first cutting, drilling and welding. Wink
This week I addressed the loom.
There are 2 main looms, one under the dash and one running from the dash to the engine on the left hand side of the enginebay under the fender.
On the right side of the engine bay there is a loom also, this one consist of 96% ABS wiring, only 2 wires are for the blinkers.
Because of the cage and therefore even less space available between the heater and chassis I wanted to get rid of the ABS wiring, as I won't be using it anyway.
So I spent this week cutting the loom and researching the wiring diagrams.
Today I finished cutting and this coming week I will install the cable as is and reroute it so it fits nicely and without stres.
Then I will tiewrap it in place and tape it shut, resulting in a loom that won't scrape anywhere and is fits stressless between all the components. Smile
Starting with diagrams in reach :
Chaos to everyone who doesn't where everything goes, so that's everyone but my I guess Big Grin
ABS wiring:
This is how the put together wiring t the factory, no welding, cold fusion rules :
All ABS wiring removed from the plugs:
Hidden deep at times:
Operation table:
The result:
Tim, a friend of mine, was working on the dashboard:
Random pic of the car:
This is the color combo I was thinking of, maybe a bit lighter shade of grey though:
01-27-2008, 09:21 PM
Post: #78
looking good Thumbs up!
he ik heb nog een set rota boost velgen liggen in gunmetal niks voor jouw?
greetz dennis
Burn rubber and not your soul
01-28-2008, 02:30 AM
Post: #79
matte black will look fanatstic
01-30-2008, 01:15 AM
Post: #80
Hoi Dennis,
Ik ga voor Advan of Work of Volks denk ik. Wink
While removing tape from the loom I accidently had cut of a wire that I had to repair.
I figured why not take pics of the proces?
So I did.
Strip the 2 wire ends:
Take a wire-end shell (most likely not the correct word for this item, if anyone knows please say it Wink ) and remove the plastic end of it:
Put the 2 wire ends in at either side of the shell:
Use the special tool:
And finish it off with some isolation:
Simple really. Wink
The car is on some STI wheels now, the Rota's are going back for repairs and won't return, time for some different wheels:
A friend of mine dropped by and we started on the FMIC set-up.
So we started of by cutting stuff away Big Grin.
I must say, this going to be very nice indeed:
The loom is in the car again, ready to be tie-wrapped in place:
  1984 Celica turbo b-group restoration Roger 8 10,322 04-24-2010 05:09 PM
Last Post: corolla4agze
