Impreza Group-N project.
11-24-2008, 11:39 PM
Post: #171
Thumbs up! ohhh YES its looking nice now. Great work on the tank. This will be an awesome car.
Post: #172
I do know what a hose like that costs.
If you are building a car like you do i dont think you should economise on a piece of hose Smile
11-24-2008, 11:55 PM
Post: #173
Thanks Len. Smile
@Eric,
You got a point, if there's not an elegant option than I probably will have to get a new hose, we'll see. Wink
11-28-2008, 09:05 PM
Post: #174
Started on the new radiator, same procedure as the FMIC:
[Image: AEU86 AE86 - Impreza Group-N project.]
12-03-2008, 11:13 PM
Post: #175
Small update.
Yesterday I spent alot of time making a cardboard dummy for the feulfilter bracket, lots of time little progression.
Also the rear brakeline connectors went in:
Today I started on making the chassis ready for the radpack.
First up is the bottom beam:
Endtanks are on the radiator!!
Welds?!?! Papertape is all we need!
A bit of sawing:
A bit lower but still a long way to go:
More cutting and hacking later!
12-07-2008, 02:31 PM
Post: #176
this project is NUTS!Big Grin
great work! respect mate!
adam
12-12-2008, 09:13 PM
Post: #177
Thanks m8! Big Grin
12-12-2008, 09:15 PM
Post: #178
Hmmm..
Killed my second radiator today....
I made a mistake removing the original endtanks, damaging the material inside.
It had to welded a bit and that went wrong.
So another one next week.
Then I went to the positioning of the cores, I planned to keep the bottom part, but after much grinding etc. I had to conclude that it all had to go.
Making a new one from scratch.
Did some panel beating on the left and right front plates, they had been damaged during the crash.
I'm pretty happy with the result, when it's painted you won't know it had any damage at all.
Also because the bumper will be in front of them....
Finally I did a first trail fit for the 2 cores.
This position is too way low, will be fixed!
Leftover, not much but much to weak:
Be gone I tell you!!:
Hammered:
Dry fitting:
Tommorow more..
12-19-2008, 07:07 PM
Post: #179
Just pics, no story this time.
Radiator nr3:
Hanging out with nr.2:
Getting to this point quicker and better after 3 tries Smile:
Then these:
Welded together soon I hope!
01-01-2009, 10:57 PM
Post: #180
Fire burnt the factory I work yesterday: http://112bollenstreek.nl/index.php?opti...&Itemid=55
Lost a dashboard heater control panel, and my Brembo brakes. Sad
  1984 Celica turbo b-group restoration Roger 8 10,322 04-24-2010 05:09 PM
Last Post: corolla4agze
