Installing adjustable camgear...
09-04-2005, 01:11 PM
Any thoughts on this. Can they be installed without any hazzle, i´m kinda conserned that the timing may be off too much. But i was hoping to be able to install them when doing the timingbelt replacement, without being able to have them fine tuned any day soon.
My evil Red/Black Panda
My current JDM AE86 project
09-04-2005, 02:50 PM
Hi Peter, i would expect that is you set them to 0, centrally or how ever they are marked, then they would be the same as stock.
[Image: AEU86 AE86 - Installing adjustable camgear...]
09-04-2005, 09:56 PM
Vernier pulleys, eventhough they have a 'zero' marking, rarely actually time in at the same stock timing figures.
If you are not going to at least check the timing on the engine when installing them, then i wouldnt bother.
The easiest method is to measure lift at TDC.
09-04-2005, 10:20 PM
Thanks all....you just said what i thought, so i´m guessing i´m not all wrong then.
09-04-2005, 10:28 PM
BenR Wrote:The easiest method is to measure lift at TDC.
Can u be more specific Benr???
09-04-2005, 10:49 PM
Most people time in cams to the peak angle method, where you measure maximum lift at say, 110 degrees ATDC.
This method is flawed and inaccurate in my opnion as you have to take the average of both sides of the cam nose.
The method i use is to measure the lift at TDC. Set the engine to TDC, and set the intake and exhaust cams to the value they should be reading at TDC. This is more accurate because there is no space for error as you are measuring the flank of the cam lobe. The only thing you have to make sure of is that you are at the true TDC.
Use a DTI to measure lift on the bucket, and make sure you are measuring at the same included angle of the valve so you dont induce a lift ratio.
When i time in a cam i ignore the marking on the pulleys, they mean nothing, i only reply on the lift figures.
09-05-2005, 10:01 PM
BenR Wrote:Most people time in cams to the peak angle method, where you measure maximum lift at say, 110 degrees ATDC.
I think i´ll leave the actual cam timing to a pro shop with a dyno. I was just curious to hear if i could go all wrong on timing and lift by installing at Zero degree setting on the camgear, and then adjusting the timing afterwards.
But very interesting reading there BenR....all new stuff to me. Cool
09-05-2005, 10:06 PM
in that case you can time into zero then..........then get them setup after by someone who can...no problems! Thumbs up!
  Need help installing replica "OEM" sideskirts sheppardpat47 3 1,234 08-09-2026 12:46 AM
Last Post: sheppardpat47
  Build your own adjustable fuel pressure regulator ;) oldeskewltoy 8 26,595 08-19-2018 12:08 PM
Last Post: AlexKTM
  Start wont turn over after installing radio MC_JP 6 13,336 09-22-2014 11:13 PM
Last Post: izanagi
  Problems installing yellow koni's in my TE71 liftback teun 12 20,542 11-09-2013 03:01 PM
Last Post: teun
  probs installing Battle Version #2 kit, please help cj 10 18,780 11-28-2012 03:25 PM
