Interchangeable parts AE86 92 101 111 ?
12-13-2005, 09:40 PM
Which parts from AE92, 101, 111 and other similar Toyotas are interchangeable or have to be modified a bit to fit on AE86 ?
thx markus
12-13-2005, 10:00 PM
Mostly engine parts are swapped into AE86's, Something like AE92 has the best cylinder head, AE101 con rods, and AE111 crankshaft would be the best engine you could make using OE parts.
Most of the rest of the car is junk as the others are FWD
12-13-2005, 10:23 PM
and what about the brakes, drivetrain, suspension,... ?
it's not only about OE parts , it's more the aftermarket parts i'm interested in
i.e. when i see something on ebay :roll: and there is only AE92 mentioned i don't know if it will fit my ae86
12-13-2005, 11:34 PM
probably not, ae92,101 and 111 are FWD cars, hence (engine aside) most parts will not fit. perhaps some suspension parts if modified.
12-14-2005, 07:53 AM
i thougt i've read something about that someone has put ae92 coilovers in his ae86. is that possible with little modification?
anyway, thanks for answering Thumbs up!
12-14-2005, 08:40 AM
Why bother? The AE86 has lots more performance parts available..
BTW, most coilover sleeves have similar diameters so yes you can probably use them. What many people do is use the front shocks
from ae92's for their short-stroke coilover conversions..maybe that's what you meant?
  AE 101 - 111 ITB Question, please help ZDoman 12 15,218 02-03-2013 09:39 PM
  ECU and Loom: Are they interchangeable? 127 Boy 4 5,623 01-11-2010 06:00 AM
Last Post: Chrisso
  Do you know something about this map sensor? DER DA-101 Sgonzalez 2 3,697 04-27-2009 02:12 AM
Last Post: Sgonzalez
