05-13-2006, 03:39 PM
Post: #171
Ivans hachi soon is going to be more brand new steel then 23 year old rustSmile
Good stuff man! I have a feeling that when I am back from HK that car of yours will have been completely transformedSmile
05-13-2006, 08:52 PM
Post: #172
To get back to my posting about the right-arches:
I took an inventory today since I was going to wash the hachi and found out the rust behind the bumper became much worse, probably due to it not being mounted properly. Crying
To indicate the size of my problem I've drawn it on the pic attached. Undecided
So, I am really interested in that particular part of your car if yours isn't gone as well. Tongue
[Image: AEU86 AE86 - Ivan's coupe: bodywork is done]
05-13-2006, 09:29 PM
Post: #173
Banpei, the bit behind the bumper can be replaced by any bit of metal, its behind the bumperSmile
As for the arch, auch that looks like a big hole but again I think its pretty doable with a bit of body work from another toyota that is similar to a hachi.
05-13-2006, 10:48 PM
Post: #174
Mux213 Wrote:Banpei, the bit behind the bumper can be replaced by any bit of metal, its behind the bumperSmile
That's true, but I figured it would be easier to replace it as a whole. Smile
05-14-2006, 12:33 AM
Post: #175
banpei Wrote:That's true, but I figured it would be easier to replace it as a whole. Smile
Easier and better but $$$
05-14-2006, 12:35 AM
Post: #176
We'll see.. the right side is not really rusted in that spot on the wheelarch..more towards the bottom of the wheelarch and around the rear light cluster. We'll just have to wait and see how the quarter panels look once they're off. I do hope to set a date for the whole operation sometime this week. If I need to order the rear panel from toyota myself, so be it.. On another sidenote I have probably found an engine that's had a lazy life behind it for a small sum..so I can remove my current oil-consuming 4AGE that has probably had a bit more abuse (some from me as well I must admit).
05-15-2006, 10:28 PM
Post: #177
My rust is a bit more upwards.
Posted the images of mine in my own topic. Wink
http://www.aeu86.org/viewtopic.php?p=43556#43556
05-16-2006, 07:01 AM
Post: #178
I think I'll be able to help you out with that if all goes well.
05-16-2006, 05:50 PM
Post: #179
Ivan141 Wrote:I think I'll be able to help you out with that if all goes well.
Cool! Smile
Bas also opted to have a better inspection upcoming "sleuteldag" Wink
05-18-2006, 07:03 PM
Post: #180
I guess you solved your ignition key problem. I spotted your car again today...
  My little (not really...) project - Soon to be all done?!? Jan Pedersen 516 581,879 06-27-2013 12:28 PM
Last Post: T_AE86
  Another SR20DET conversion allmost done :) peter møller 7 15,617 05-04-2011 01:16 PM
Last Post: worholm
  Yay! Its now done and on the road! Black Betty 24 22,059 01-20-2006 08:12 PM
Last Post: Black Betty
  Bodywork in 3 steps max_ae86 67 59,263 01-03-2006 02:34 PM
Last Post: Apolan
User(s) browsing this thread: 24 Guest(s)
