JDM Ae86 eletric wiring diagram:the same EU/AU/US?
12-01-2009, 04:42 PM
Or it's different?
12-01-2009, 05:35 PM
Mattolo Wrote:Or it's different? yes it is different. there are a lot of differences. |
12-01-2009, 06:35 PM
Any one have some documentation of JDM Version?
I found the pdf of EU/AU version and the USDM versione here on ae86u.org. |
12-02-2009, 12:23 AM
do some research on toyodiy... http://www.toyodiy.com
look up different harnesses, and cross check part numbers. same # means the same wiring, different #, means it likely is different Dan - You can | .... OR you can ask for help!!! OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
12-03-2009, 12:10 AM
The EU RHD loom is almost the same as JDM in the earlier years. For the later cars, the loom changed quite a bit. USDM loom is totally different.
What specifically are you trying to find out. I have other resources depending on how much you need. |
12-03-2009, 06:58 PM
parrot Wrote:The EU RHD loom is almost the same as JDM in the earlier years. For the later cars, the loom changed quite a bit. USDM loom is totally different.I need the wiring diagram of the front light, including the fog light and the bumpers light of a Levin JDM Kouki. |
12-05-2009, 04:28 PM
Send me a PM with an email address.
Let me know the date of manufacture if possible. Just had a look at your photo album. Have been through the same as you with mine! |
Tail light wiring... | Mylesmck | 4 | 936 |
02-02-2024 12:36 PM Last Post: Mylesmck |
Lambda sensor wiring | sam3007 | 10 | 4,262 |
4A-GE wiring engine to chassis connectors | Lykowsky | 4 | 6,859 |
06-20-2019 11:38 AM Last Post: Lykowsky |
Some wiring help needed | DJexor | 5 | 5,402 |
AE86 Headlight + wiper wiring (levin) | bozu | 11 | 15,752 |
09-19-2017 02:06 PM Last Post: banpei |
