JDM Ae86 eletric wiring diagram:the same EU/AU/US?
12-01-2009, 04:42 PM
Or it's different?
12-01-2009, 05:35 PM
Mattolo Wrote:Or it's different?
yes it is different. there are a lot of differences.
12-01-2009, 06:35 PM
Any one have some documentation of JDM Version?
I found the pdf of EU/AU version and the USDM versione here on ae86u.org.
12-02-2009, 12:23 AM
do some research on toyodiy... http://www.toyodiy.com
look up different harnesses, and cross check part numbers. same # means the same wiring, different #, means it likely is different
Dan -
12-03-2009, 12:10 AM
The EU RHD loom is almost the same as JDM in the earlier years. For the later cars, the loom changed quite a bit. USDM loom is totally different.
What specifically are you trying to find out. I have other resources depending on how much you need.
12-03-2009, 06:58 PM
parrot Wrote:The EU RHD loom is almost the same as JDM in the earlier years. For the later cars, the loom changed quite a bit. USDM loom is totally different.
I need the wiring diagram of the front light, including the fog light and the bumpers light of a Levin JDM Kouki.
12-05-2009, 04:28 PM
Send me a PM with an email address.
Let me know the date of manufacture if possible. Just had a look at your photo album.
Have been through the same as you with mine!
  Tail light wiring... Mylesmck 4 1,191 02-02-2024 12:36 PM
Last Post: Mylesmck
  Lambda sensor wiring sam3007 10 4,755 05-23-2022 10:00 PM
Last Post: The Doctor
  4A-GE wiring engine to chassis connectors Lykowsky 4 7,213 06-20-2019 11:38 AM
Last Post: Lykowsky
  Some wiring help needed DJexor 5 5,629 05-18-2019 01:50 PM
Last Post: DJexor
  AE86 Headlight + wiper wiring (levin) bozu 11 16,442 09-19-2017 02:06 PM
