KE70 conversation to KE86
01-15-2009, 05:21 PM
Hey everybody
I am looking to put an KE70 i want to go N/A first then Turbocharge. I have a 30 000 dollar budget i want to maintain this is for the whole car body, suspension etc.... i heard that techno toy tuning is a good place to get stuff suspension wise any other place i can get stuff would b appreciated greatly.
Gearboxes i have done some research and from out the AE86 bow is every weak and W series box A.K.A Supra box is my best bet on less i go Quafie. What other boxes can i use beside them r stick with the W series one?
Engine Now!! for when i am N/A 20 valve r 16 valve r buy a 4A-GZE one time and take off Supercharger run open 20 valve Throttle bodies with two 284 cams so i can still use the VVT or 7A-FE don't know what engine to use all i know i want to hear open trumps on an N/A engine and when i go turbo i don't have to spend no lot of money on the engine for it to go on boost.
i want to best of both worlds
last but not lease the rear end go full AE86, Carina, Celica which is best for what i want to do.
01-15-2009, 06:54 PM
I have a ke70, everything form the ae86 fits on it like a glove!
only part that is different is front shocks, depending on the year the ke70 was build.
01-15-2009, 06:58 PM
Ok good to know so stick with the AE86 rear then should b able to with stand both boost and N/A treatment? What gearbox r u using?
01-15-2009, 11:04 PM
i am using a t50, std. 4age box on my 4age20v engine.
std. rear, dunno if that will hold boost, you can use a rear axle from a hyundai van or something.
te71corolla is using one for his sr20det powered ae86.
01-16-2009, 12:46 AM
hmmmmm ok i well check that for real. Thanx for that what colour u thing should use for the car if i using these rims
http://www.nlmotoring.com/v/vspfiles/pho...082R-2.jpg
01-16-2009, 12:56 PM
Eric Wrote:i am using a t50, std. 4age box on my 4age20v engine.
What issue did you use for the hydraulic clutch?
1982 Toyota Corolla KE70
1992 Subaru Legacy BF5T
01-16-2009, 01:54 PM
trust me so far the OEM rear end can handle boost Smile
  Conversation 4x114.3 to 4x100 Serencebey 4 5,573 05-04-2009 02:13 PM
Last Post: Serencebey
