KONI YELLOW´s - fitting / adjusting info
11-25-2004, 02:03 AM
11-25-2004, 02:04 AM
part 2
11-25-2004, 09:21 AM
Damn,its hard to see detail on those scans, can you email me higher resolution?Smile
11-25-2004, 11:30 AM
mux213 Wrote:Damn,its hard to see detail on those scans, can you email me higher resolution?Smile
no email, put them up here! Smile
I want better res. too!
[Image: AEU86 AE86 - KONI YELLOW´s - fitting  / adjusting info]
11-25-2004, 12:05 PM
hmmz its not hard
to adjust a koni
press it in full to the buttom than you can turn it left or right
tighten or losen it.
When you tighten it the bound rate will be minimized. So simple bring it down till the button than you can turn it .
Best way in my exp is to turn it full.. than losen it for 1/4 turn.
11-25-2004, 12:17 PM
robokill Wrote:Best way in my exp is to turn it full.. than losen it for 1/4 turn.
That´s the official way Wink
No no no noooooooooooooooooooo
11-30-2004, 11:08 PM
Ah I finally did my rear konis!!Smile
Lift one side of the car up but dont lift wheel off the ground
Unbold koni at the top
Compress fully
then turn to adjust, they have 2.25 turn side to side, no clicks, fully adjustable.
Also contrary to what people have told me, these STIFFEN clockwise and LOOSEN anti-clockwise when being adjusted like this (depends which way you look at it really). I put them on 1.75 stiff, they where at 0.25Smile
I haven't had time to take her for a real spin but on the drive from the garage back home she felt alot more steady! I think I'm gonne be very happy with this changeSmile
Fronts I'll do later, need to get my coilovers in first.
12-01-2004, 02:23 AM
Nice work...I'm sure it will make a lot of difference.
12-01-2004, 10:35 AM
the koni that are off my car i have adjustet already just have to apply them to the car...
  Fitting Air Con (No PS) to LHD AE86 pack 7 4,188 01-07-2024 11:36 AM
Last Post: CCB
  Fitting Fibreglass Kouki Lip? chrisae86 3 2,128 02-25-2022 08:14 PM
Last Post: chrisae86
  KONI Sports shocks for the AE86... jondee86 11 20,707 09-08-2017 03:38 AM
Last Post: jondee86
  Fitting driftworks CS2 coilovers bozu 2 4,722 05-30-2017 10:50 AM
Last Post: bozu
  Toda timing info - with good general 4AG timing info too oldeskewltoy 0 4,310 11-05-2016 01:34 AM
