Kajoba Works 4A-GE 16V dual-plenum intake manifolds
08-07-2015, 01:10 PM (This post was last modified: 12-05-2017 01:27 PM by kjb.)
[Image: AEU86 AE86 - Kajoba Works 4A-GE 16V dual... manifolds]
For RWD turbo installations!
- velocity stacks
- 65mm billet throttle body, black or silver anodized (only black available at the moment)
- main plenum displacement 1.5x engine displacement (2.4l)
- 4x 4mm hose connections for fuel pressure regulator, gauges, boost controller and whatnot.
- 2x 10mm hose connections for brake booster and IAC-valve.
- durable black wrinkle paint
NOTE! I'll update the photos ASAP to show the black throttle body as well.
The benefit of a dual-plenum design is the more equal distribution of air for all cylinders in a turbo application. Usually this comes with a small drop in peak power but also an increase in response and driveability due to a smoother torque curve. Excellent choice for a daily driven / trackday / circuit racing vehicle Smile
Currently out of stock, will update when available again.
Kajoba Works
[email protected]
http://www.kajobaworks.com / http://www.facebook.com/kajobaworks
08-20-2015, 03:05 PM
Really nice part that, great work
08-20-2015, 07:00 PM
very nice item...
  Kajoba Works *E7 & AE86 weld-in chassis braces kjb 20 33,505 04-27-2017 11:27 AM
Last Post: fantapants
  Sakura Fab: 4AG Heat Screen Intake Manifold Gasket dr.occa 1 5,925 12-27-2013 07:50 PM
Last Post: dr.occa
  K1 MOTOR WORKS KOUKI LEVIN FRONT HEADLIGHT SET **COMPLETE** yversion 9 13,074 07-01-2011 02:27 AM
Last Post: yversion
  K1 MOTOR WORKS SWIFT FRONT SPRINGS 8KG yversion 1 5,210 05-17-2011 12:12 AM
Last Post: yversion
  Dual Carb T-Shirt Shift Gear S-4XL tomstwincam 6 7,378 11-22-2010 02:24 PM
Last Post: tomstwincam
